MAF Diameter
Old Feb 12, 2010 | 07:58 PM
theoz385's Avatar
theoz385
Default MAF Diameter
Silly question I know, can anyone tell me if the outer diameter of a MAF is the same as the advertised diameter? Meaning, is an 85mm MAF 85mm on the inside or the outer diameter that the hose slides onto? Thanks
Old Feb 12, 2010 | 09:02 PM
lucky131969's Avatar
lucky131969
I would hope it would be the id.
Old Feb 12, 2010 | 09:19 PM
PewtVette's Avatar
PewtVette
I just happened to have one sitting in front of me. It's definitely ID.
Old Feb 12, 2010 | 09:23 PM
theoz385's Avatar
theoz385
Can you adapt an 01-04 85mm MAF to a 97-00. I have a 99 w/ an LS2 402 and would like to bump up to the larger MAF, other reason is because I have an 01-04 Halltech CAI that requires the 85mm. Thanks
To MAF Diameter
