CTEK users-
Old Feb 14, 2010 | 11:34 AM
bobby777's Avatar
bobby777
Default CTEK users-
on the model 3300--when the chargers light says fully charged IS there any juice going to the battery or is the unit shut-off and waiting for the voltage to drop and than give it some juice? thx.
Old Feb 14, 2010 | 12:18 PM
TotaledmyGN's Avatar
TotaledmyGN
If the battery is fully charged the charger should be in the "pulse" mode. This mode will maintain the battery between 95%-100%. The battery receives a pulse if the voltage falls. This stage willl keep your battery in good condition if it is not being used. I got that information from the instructions with the charger. I would say there is no juice and then a small current to top up the battery and this process repeats itself over and over.
Old Feb 14, 2010 | 02:09 PM
FRCTony's Avatar
FRCTony
This should help.
http://www.ctek.com/Manuals/new_US3300_EN.pdf
Old Feb 14, 2010 | 04:11 PM
bobby777's Avatar
bobby777
thx guys for the help--i think ill look into the batteryminder as i like there constant pulse and you can set the float volts yourself
To CTEK users-
