Diff. output shaft seal
Old Feb 14, 2010 | 09:56 PM
2scmpny's Avatar
2scmpny
5th Gear
Default Diff. output shaft seal
My 98 is seeping at the output shaft seals. More so on the right side. After I drive it for a while and park in the garage for a few days there is a silver dollar size spot on the floor. Not like a puddle. More like a film. [The floor is epoxied] When I removed the plug to check the oil level there was pressure in the diff. Is this normal or is my vent not working?
Old Feb 14, 2010 | 11:41 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
The diff should not be pressurized. Is there dirt on the vent or anything on the outside blocking it?
Old Feb 15, 2010 | 01:07 AM
2scmpny's Avatar
2scmpny
5th Gear
Default Diff. output shaft vent
The vent and area around it are clean. The vent cap is not stuck. Is there a vent valve that could be malfunctioning?
Old Feb 15, 2010 | 08:31 AM
jeff keyuk's Avatar
jeff keyuk
Sounds like seals are done! There know to leak.
Old Feb 15, 2010 | 09:53 AM
wcsinx's Avatar
wcsinx
Every C5 ever built left the factory with a leaking axle seal. It ain't "if" it's "when". Normally it's the driver's (left) side that leaks though.
Old Feb 15, 2010 | 10:16 AM
Fast one's Avatar
Fast one
When the plug is removed you should hear air going into the differental because it's under vacuum when the vent and check valve are working properly.
Old Feb 17, 2010 | 08:49 PM
2scmpny's Avatar
2scmpny
5th Gear
Thanks for the info. Anybody know the cost to replace the seals? Or what the flat rate time is?
Old Feb 17, 2010 | 11:21 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
I was quoted around $400.00 from a couple local Detroit area dealerships.
I'm going to get mine fixed this spring when I pull it out of winter storage.
Good luck,
Silverbird.
Old Feb 18, 2010 | 09:08 AM
wcsinx's Avatar
wcsinx
Good luck,
Silverbird.
Was that for just the shaft seal or both the shaft and cover? They're both known to weep. That's a fair price for both but way high for just the shaft seal.
Old Feb 18, 2010 | 10:44 AM
jedblanks's Avatar
jedblanks
Mine is doing the same thing. How urgent is it to fix?
It is literally just a dime sized film on the epoxy floor. Not sure I would have even seen it on a regular concrete floor.
I've heard that this can happen after spirited driving from the vent. Will I see more if it becomes a problem? Or will I just end up with an empty (and therefore toasted) differential?
I would rather do clutch, output shaft, seals all at the same time but my clutch is holding for now.
Old Feb 18, 2010 | 11:46 AM
wcsinx's Avatar
wcsinx
Define "urgent"
It ain't gonna fix itself, but catastrophic seal failures are very rare. I knew mine was leaking when I bought my car, but I let it go for nearly a year. I did however periodically check the diff. fluid level. What did finally motivate me was the leak went from just being able to "moisten" the cover to actually leaving a tiny puddle on the floor like yours. Seeing that got me off my azz, and I ordered the parts. It took me about 4 hours, but a lot of that was headscratching as I tried to figure out how to jimmy out the cover without removing the halfshaft from the wheel hub. There isn't much room, but I did finally get it though!
Old Feb 20, 2010 | 12:03 PM
2scmpny's Avatar
2scmpny
5th Gear
Looks like a fair amount of work for the price. Would do it myself but would rather have the dealership do it so I can go back if it starts leaking again.
Old Feb 22, 2010 | 08:27 AM
wcsinx's Avatar
wcsinx
It's a very easy job.
Old Feb 22, 2010 | 02:44 PM
jedblanks's Avatar
jedblanks
Honestly, I don't see any dampness anywhere on the differential, just the film on the floor. Where is the vent hole?
Old Feb 22, 2010 | 03:31 PM
wcsinx's Avatar
wcsinx
Very top, driver's side
Is the side cover coated with grease?
To Diff. output shaft seal
