Injectors? Sizes?
Old Feb 15, 2010 | 02:53 AM
HD_2_C5's Avatar
HD_2_C5
Default Injectors? Sizes?
I have an 02 vert. I'm thinking of doing headers leading to the Borla catback. I already have a CAI and will probably do a velocity stack to improve air flow. So that will achieve some degree of admirable air flow in and out. With increased air flow, should I be looking into larger injectors? If so, any suggestions? I see the various sizes but no clue what I have or what I should have. I won't be getting any more involved than the headers and the CAI for a long time.
Old Feb 15, 2010 | 03:04 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
You wont need bigger injectors with the mods your going to do, your stock ones will be fine. I would get a tune just to free up some lost power with the headers.
Old Feb 15, 2010 | 08:37 AM
jeff keyuk's Avatar
jeff keyuk
The motor will lean out! Do you have a wide band! yes you will need a new tune!You might get a code reading slow respones to bank1 02's.
Old Feb 15, 2010 | 10:50 AM
Blow Torch's Avatar
Blow Torch
I had H/C and all mods, making well over 400rwhp and hadn't maxed out my stock 28psi injectors (same ones you have)
Just get a tune to max the new airflow.
To Injectors? Sizes?
