Misfire problem
Old Feb 15, 2010 | 07:39 PM
Quick 68's Avatar
Quick 68
Default Misfire problem
I got some new Katech valve covers with the coil realocation kit, painted the intake manifold, and installed some billet fuel rails. I am not getting a misfire. I checked all the wires to make sure they are pushed on properly. I had someone hook up their laptop and the passenger side 02 sensor was showing a really rich condition. The guy that did this seems to think that the coil packs are not grounded out properly. Does this sound like a possibility or do you guys have any other suggestions?
Old Feb 15, 2010 | 07:53 PM
lucky131969's Avatar
lucky131969
Ok...make up your mind here....
The coils are grounded through the harness at G107 behind the drivers side head. Sounds like you have it isolated to a bank. I'd go over your work, checking the coil/injector harness....plug wires, etc.
Old Feb 17, 2010 | 08:52 PM
Quick 68's Avatar
Quick 68
Sorry about the typo. I am getting a misfire. What do you mean when you say G107?
Old Feb 17, 2010 | 09:03 PM
fastyellowss's Avatar
fastyellowss
If you can get ahold of an infrared thermometer, you can take the temp of each exhaust (on the exhaust manifold/headers close to the head), and it should show one or more with a much lower temp. That will show which cylinders are causing the misfire. Then check those wires, plugs etc.... If you cant get it from there, change one coil pack from a cylinder thats ok and check to see if that one is cooler. If not, change the wire and try again. then the plug if not.
Old Feb 17, 2010 | 10:01 PM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
Were there any other codes? You should have a misfire code as well, that should indicate which cylinders are misfiring.
Old Feb 17, 2010 | 11:00 PM
lucky131969
G107 is the ground location(as listed in the service manual) at the rear of the drivers side head.......grounding the coil packs...
Are the coils getting a good ground?
Old Feb 21, 2010 | 10:49 PM
Quick 68's Avatar
Quick 68
Ok I found the problem. I had one of the coil pack harnesses flipped the wrong way or had it on the wrong side. Thanks for the suggestions guys.
To Misfire problem
