how do you check Automatic transmission fliud???
i also want to change the oil is there a filter kit and gasket?
what oil should i use?
how do i check it when i have completed the oil pan change?
Or what is required to change out fliud and filter and gasket?
gonna do this my self ..
please i use use some help here .. thanks guys
Proper fluid level is the bottom of the fill hole on the side of the pan.
Wear mechanics gloves to avoid burns from the exhaust pipe.
Without special equipment you will only be draining and replacing a portion of the fluid. (Five quarts out of about 11 quarts if I remember correctly)
Yes, you can purchase a filter & gasket set.
so do you fill through the oil pan plug?
what kind of tranny oil should be used..???
the manual suggest Dextron III ...is this ok ?
As for checking, I've always suggested to get the fluid warmed up by simply taking a drive.
1) orginal dextron 111 can be used manuals suggest it.
2) syntheic dextron 6.. which will require full flush which is suggested by others
the problem is YOU CANNOT GET a direct answer from the dealer of which tranny oil they are replacing .. they say replace with orginal. BUT when, done is it?? i ask this morning and that's what i got for answer..
would any one care to make comment???
ok dealer got back.. they said they will top up any chevy vechicle with D-6, it has no problems mixing with D-3. D-6 enhances the properties of ... to further they only use d-6 in shop the prevent other fliuds entering new vechicle..
so..
1) it seems when repairing the tranny gasket and done in dealer. you will get new gasket (filter if requested), top up (approx 4-6 liters) of D-6. cost of about 1.4 hr labour
2) in tranny flush. all oil is replaced (about 11-12 liters) @179.95. no gasket( in my case, the gasket leaks) , no filter ( add as extras) plus 1.4 hr labour
another question: could the oil be change completely at home ( garage) HOW?and when does the filter and gaskets be replaced? before or after fliud changed?
hi sonny,, a NOVICE??? IMOA
better to ask! then to screw up a corvette tranny with less then 35.000km !!!.. so now the oil has warmed up.....jeez
i would use a blow torch yeh!!!
BTW thks for your suggestion, Are you new to the forum??
The most important part of any autotrans fluid service is to replace the filter whether or not you get the unit flushed.
Bill
Bill
i AGREE Totally.. i bought new filter and gasket.. while i under the car i change all of it.. piece of mind..
i too have changed only filter topped up, in passed and miled chey 1 ton 460,000km with no problems.. i would say that the most important part THE FILTER..
thank you ..
i have completed the gasket and filter change by following the instruction of the veteren corvette owners ..thanks to each and everyone corvette owner that help!!
Thank you !
korvette4u
Aka dennis
