Rpm question
Old Feb 18, 2010 | 07:33 PM
eezynow's Avatar
eezynow
Default Rpm question
I have a c5 with 6 speed an I'm turning 1500 rpm at 70 mph and a buddy of mine has a c5 with automatic an he's turning 2500 rpm at 70 mph , I understand that I have six gear's but still 2500 rpm at 70 mph for him seem's like alot is that normal?
Old Feb 18, 2010 | 07:40 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Has he changed his gears?
Old Feb 18, 2010 | 07:58 PM
eezynow's Avatar
eezynow
no, but not original owner, it's a 03 50th anniversary edition dont know if that means anything,
Old Feb 18, 2010 | 08:16 PM
0331MARINE's Avatar
0331MARINE
Not really sure then. Im sure an auto guy will jump in.
Dennis Wilson's Avatar
Dennis Wilson
What gear are you in going 70 at 1500 rpm?
Old Feb 18, 2010 | 08:40 PM
65GGvert's Avatar
65GGvert
If the automatic has 2:73 gears, he should be turning 2730 rpm in 3rd gear and 3150 if he has 3:15's. You should be turning 3420 rpms in 4th gear with 3:42's with the 6 spd. All this is at 75 mph in the gears noted.
Old Feb 19, 2010 | 11:52 AM
Vette-Dream's Avatar
Vette-Dream
My auto would sit around 1800 in 4th (OD) around 70 on the freeway if I remember correctly. I've since replaced my stock 2:73 gears with 3:42 gears and now it's around 2200 in 4th at the same speeds... these numbers are from memory, I haven't driven all winter so they may be off slightly.
Old Feb 19, 2010 | 02:51 PM
Jewjenk's Avatar
Jewjenk
Did he have the overdrive turned off?
Old Feb 19, 2010 | 05:01 PM
eezynow's Avatar
eezynow
Default thank's
don't know about him being in od but will ask , and thank's for all the info guy's ,very helpful as usual
Old Feb 19, 2010 | 05:05 PM
FASST LN's Avatar
FASST LN
To recap, it sounds like he either had the overdrive button clicked or there are 3.73 gears installed.
Old Feb 19, 2010 | 05:09 PM
chaase's Avatar
chaase
St. Jude Donor '12
He was in 3rd or the TC is forked and its not locking up. I have 3.42's and 70mph is 2200ish RPM.
To Rpm question
