Mytery Rattle (C5Tech or Anyone)
Old Mar 8, 2002 | 01:55 PM
gonbad's Avatar
gonbad
Default Mytery Rattle (C5Tech or Anyone)
I have a rattle under the car. It does not seem to be associated with overall suspension travel. It occurs when on rougher surfaces and seems to be coming from the passenger side front to middle of the car. It is not a high pitched rattle it is more like something coming in contact with the frame. A pronounced thumping. I jacked the car up and the exhaust and shielding seems tight. All the bolts seem in place for the tunnel cover. There doesn't seem to be any looseness in the front suspension. No unnormal movement. So any other ideas?
:mad
Old Mar 8, 2002 | 03:04 PM
Blocktrdr's Avatar
Blocktrdr
Default Re: Mytery Rattle (gonbad)
Check sway bar links/bolts. Check the rears too. This car can fool you on where the sounds come from.
Old Mar 8, 2002 | 07:07 PM
David-F's Avatar
David-F
Default Re: Mytery Rattle (Buckmaster)
I would agree a swaybar end link nut is mostlikly the cause especialy if it's more apt to happen over light bumps and more so at one wheel or the other.
David Fulcher
Old Mar 8, 2002 | 11:02 PM
racetchr's Avatar
racetchr
Don't know if you have changed your shifter, but mine developed a similar strange rattle ( only occasionally) after installing Kirban Kwick Shift. I have had the console apart and looked everywhere I know to look and it stays! Very annoying. I know this didn't help but I am glad I am not the only one with a strange rattle.
To Mytery Rattle (C5Tech or Anyone)
