OEM master cylinder won't work with Spec....
Old Feb 19, 2010 | 11:23 AM
SouthernSon's Avatar
SouthernSon
Default OEM master cylinder won't work with Spec....
I suppose I am one of the unlucky ones. My SPEC 2 will not disengage with the OEM master. No problem until the swap. New TICK on order ATTM.
Old Feb 19, 2010 | 01:24 PM
lucky131969's Avatar
lucky131969
Isn't the spec clutch one that may require shimming? Also, did you replace the slave?
Old Feb 19, 2010 | 03:40 PM
Brandon619's Avatar
Brandon619
Nope, I've been running a Spec Twin for over a year now and no shimming was needed. I did upgrade to a tick a few months back great master!
Old Feb 19, 2010 | 04:55 PM
USAFZ06's Avatar
USAFZ06
maybe your stock worn out master isnt up to the task assuming you installed correctly measuring for a shim or not...was it installed?
Old Feb 19, 2010 | 05:00 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Originally Posted by Brandon619
Nope
Umm, yes.
Spec is notorious for needing slave shimming, so much so they include the shim with their clutch kits.
Not everyone will need it, but it's something that should be measured for at the time of installation, and used if need be.
If you don't measure, you don't know...Well, at least not until it's all reassembled and then write a post like the OP did.
Old Feb 19, 2010 | 06:04 PM
Carcass's Avatar
Carcass
No shim on my '98/Spec Stage2,and it works sweet.
Old Feb 19, 2010 | 10:37 PM
trackboss's Avatar
trackboss
If your m/c is functioning properly replacing it will not solve your problem. If you were to install a new m/c with larger bore to try and extend the throwout bearing more it will blow the seals and damage the t/o. Could also damage the diaphram spring on your pressure plate. The shimming suggested above is what you probably need to do. In general, you want the t/o bearing to be about 1/8" away from the fingers of the diaphram. No more than that. A little less may ok depending on pressure plate. Check with the mfg. It's still a good idea to install the tilton m/c that tick sells as it is an improved raplacement, but will still require the shimming unless your current parts are not working as they should.
Old Feb 20, 2010 | 08:19 AM
SouthernSon
Called Spec and they said that even though the C5 did not generally need the shim, it sounded like I might need it in this case. However, going with the Tick solves the problem, reduces pedal pressure, and should be much better altogether. As far as new slave, they are included with Spec kits.
http://www.tick-performance.com/tick...te/hydraulics/
Old Feb 20, 2010 | 08:26 AM
SouthernSon
I appreciate the tip on the t/o measuring. I will say this as an aside note; if anyone is considering the pfadt hard mount motor mounts AND transmission mount, be ready to shake, rattle, roll and vibrate down the road!! It is a little more than I had anticipated... Perhaps one or the other may not have been as drastic...
Old Feb 20, 2010 | 08:34 AM
USAFZ06's Avatar
USAFZ06
haha you got another thing comin if you think the tick will reduce pedal pressure...i liked the way my spec clutch felt way better prior to the Tick master install...pedal pressure seemed to increase 40% or so
Old Feb 20, 2010 | 09:13 AM
SouthernSon
Wow! That seems to be totally contradictory from the rules of hydraulics, other persons' experiences, and aftermarket manufacturers' recommendations. Are you fairly certain there is not another problem?
Old Feb 20, 2010 | 09:18 AM
USAFZ06's Avatar
USAFZ06
you must be thinking backward...no clutch pedal assist spring...larger and shorter bore in itself would induce increase pressure to push the same amount of fluid...
Old Feb 20, 2010 | 09:20 AM
USAFZ06's Avatar
USAFZ06
the tick requires less pedal movement to push the same amount of fluid so say if it takes half the distance to do the same fluid movement it will be more difficult to press
Old Feb 20, 2010 | 09:27 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Uh, no, it's actually spot on with hydraulic principle.
Trying to force a higher volume of fluid through a passage of unchanged volume will increase applied fluid pressure....which will never require less work on the input side.
A simple search of Tick master will tell you all you need to know about pedal pressure. Even Tick will tell you it gets a bit stiffer.
It has to, or their claims of higher volume would be false.
Old Feb 20, 2010 | 09:48 AM
lucky131969
Wow! That seems to be totally contradictory from the rules of hydraulics.....
What exactly are the "rules of hydraulics" ?
Old Feb 20, 2010 | 11:12 AM
SouthernSon
You guys are correct! I had read some wrong information from another source. Reading TICK's FAQs says maybe 15% increase. I hope that is not a direct correlation to pedal feel with their SPEC2 and OEM master cylinder w/o shim. Because another 15% over current configuration (albeit inadequate) would get to be a little tiresome with shifts required on some of the road courses I have been running.
Thanks again for setting me straight on this.
Old Feb 20, 2010 | 11:14 AM
SouthernSon
Old World....... "principles" .... new world. OTOH, before coffee, after coffee.
To OEM master cylinder won't work with Spec....
Old Feb 20, 2010 | 11:26 AM
SouthernSon
I suppose I could get out my old fish weighing scale and rig it up to the harness bar, configure a series of pulleys to allow full pedal travel and try to quantify the exact percentage increase but then I would have to deal with that whole ratio thingy.....
Old Feb 20, 2010 | 07:13 PM
trackboss's Avatar
trackboss
If you match the bore size of the new m/c to the original your pedal effort will remain the same all else unchanged. Tilton makes a large variety of m/c. You could ask tick to supply you with smaller bore size if their standard one is larger than factory. I have yet to get an answer as to what bore size they use. The tilton m/c's have it cast into the side.
On the pfadt mounts, I have thier motor mounts and have not noticed any additional vibration.
Old Feb 20, 2010 | 09:19 PM
ace996's Avatar
ace996
I did not find this to be the case. I removed my pedal spring before the Tick install, so I belive that may be where many find the big increase in pedal effort.
The pedal effort did increase some, but it wasn't noteworthy.
