My setup...will a bigger intake help?
Old Feb 19, 2010 | 11:43 AM
94brick's Avatar
94brick
Default My setup...will a bigger intake help?
I am having a new cam installed next week. It is a Ed Curtis custom grind that will be will going on my 02 Z with the following mods:
Kooks 1 3/4 headers
X pipe
GHL Exhaust
Vararam induction
25% Underdrive Pulley
My question is would adding a Fast 92 intake and throttle body be worth the money to add even though I am keeping the stock heads. Seems like most views say to keep the stock intake unless upgrading heads AND cam. What do you think?
Old Feb 19, 2010 | 01:15 PM
tlove32's Avatar
tlove32
A ported FAST and TB will get you 15-20rwhp over a stock LS6 intake. Personally, I think it's worth it, if you can get a good deal on one
Old Feb 19, 2010 | 03:22 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I would spend the money on better heads and a ported TB.
Old Feb 19, 2010 | 04:02 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I just bought a TPIS 90mm TB, and im about to order a FAST 92. Im going to wait until I get a good set of heads and do it all at one time. The FAST will do alot better with a good set of heads. Im buying the FAST first because its getting pretty hard to find a 92mm.
Old Feb 19, 2010 | 04:20 PM
amidei's Avatar
amidei
Spend your money on good heads like Trick Flow. Your LS6 intake will work great with a head, cam ,CAI set up. Don't waste your money on a fast 92 or ported TB. You won't see that much HP gain. (25 rwhp from Ls6 to fast 92 intake-I don't think so and a ported TB you will be lucky to gain 5 HP)
To My setup...will a bigger intake help?
