Winshield Washer Pump Always On
Old Feb 19, 2010 | 11:59 AM
BaadGoat2006's Avatar
BaadGoat2006
Default Winshield Washer Pump Always On
Guys I just changed the multi switch stalk and wiper system stalk.
Well they both were installed with out incident, however they wiper motor is staying on still! After a few choice words, I have decided to search again. So far I have came up with nothing. I have no idea where to go now.
The pink wire has constant 12 volts, I cannot find where the fuse is for the w/s washer pump or even the wipers for that matter.
Can anyone direct me further in what to check next?
Thanks,
Ryan
Old Feb 19, 2010 | 01:00 PM
BaadGoat2006
I have the meter on the wash motor plug with constant 12 volts. The only thing I can do to take voltage away from the washer pump is to turn the parking lights and or headlights on.
This thing is wearing me out!
Old Feb 19, 2010 | 01:13 PM
lucky131969's Avatar
lucky131969
You can pull minifuse #10 in the passenger footwell fuse box to disable the wipers/pump. Was the switch you installed new? Unfortunately, it is the switch assembly that controls 12 volts to the pump, so if the switch is not activated, the pump will not run.
Old Feb 19, 2010 | 01:15 PM
BaadGoat2006
yes, the switch is new from the dealer...DANG!@$#
Old Feb 19, 2010 | 01:16 PM
lucky131969
Use the schematic, and check out the switch itself with a DMM to see if the contacts remain shorted.
Old Feb 19, 2010 | 01:31 PM
BaadGoat2006
The switch checks out good, I unplugged it from the car and we still have 12 volts on the pump plug.
Still if you turn the parking lights on, the voltage goes to zero on the pump plug.... I guess it's either tracing wires through the harness or leave it unplugged.
Old Feb 19, 2010 | 01:33 PM
lucky131969
Still if you turn the parking lights on, the voltage goes to zero on the pump plug.... I guess it's either tracking wires through the harness or leave it unplugged.
Ok, what happens when you unplug the entire MFS?
Old Feb 19, 2010 | 01:44 PM
BaadGoat2006
I have not tried that yet, but I did pull minifuse #6 out and lost the mystery voltage to the pump plug.
I am going to unplug the mfc switch(it is brand new as well) right now.
I am afraid this is the result of some bad splicing at some point and time...
Old Feb 19, 2010 | 01:49 PM
lucky131969
I have not tried that yet, but I did pull minifuse #6 out and lost the voltage to the pump plug.
Yep, sounds like you've got wires shorted somewhere. Time to disconnect both ends, and start doing continuity checks on individual wires.
Old Feb 19, 2010 | 01:56 PM
lucky131969
Based on what is happening, I would think the short is downstream of the headlight switch itself. It may even be at the feed through area (P200). The headlight off input, and the pump wire both go through P200.
Old Feb 19, 2010 | 02:23 PM
BaadGoat2006
I appreciate all the help for sure.
One thing, where is P200 in/on the car? I am going to guess that it comes in somewhere around the passenger side front wheel well area. I am pretty sure the car has been hit in that spot.
Old Feb 19, 2010 | 10:01 PM
byronhunter's Avatar
byronhunter
Don't know if this will help, but it is directly from the service manual:
P200
Instrument panel harness, RH side of Instrument panel on dash panel
I know that's not much info, but that's what it list for location.
Old Feb 20, 2010 | 10:22 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
This happens all the time, udders clog, water shorts motor
pull cowl, dry out, sometimes you get lucky
relay inside motor box is prolly it
x3 t20 screws
Old Feb 20, 2010 | 11:43 PM
BaadGoat2006
x3 t20 screws
this will make the wash pump run all time?
To Winshield Washer Pump Always On
