steering colum service
Old Feb 19, 2010 | 09:31 PM
jp101's Avatar
jp101
Cruising
Default steering colum service
just experienced the shut down from the steering colum problem. had the car six years now, no recall notice. new to forum and didn't pay any thought to it. still a problem?? 60,145 miles
Old Feb 19, 2010 | 10:15 PM
dougbfresh's Avatar
dougbfresh
Guess your thinking about it NOW, CLB after you unlock it-read the sticky at the top of the Tech Section for all the GORE.
Old Feb 19, 2010 | 10:48 PM
jrose7004's Avatar
jrose7004
It's a problem that won't cure itself and can pop up when you least expect it.
Old Feb 20, 2010 | 06:14 AM
oakvillec5's Avatar
oakvillec5
I have a 1998 and finally put the CLB in last summer after getting it locked up....lucky for me it released itself after a few minutes, I already had the CLB, so had it installed a few days later.
It's true, it can rear its ugly head at any time, even after 12 years.
Old Feb 20, 2010 | 06:39 AM
nextime's Avatar
nextime
I think this was the first mod I did since like everyone said it can happen anytime, most likely when you need the car real bad!
Old Feb 20, 2010 | 06:40 PM
jp101's Avatar
jp101
Cruising
thanks everybody. 1998 auto. gonna have it towed to dealer monday.
Old Feb 20, 2010 | 06:50 PM
TotaledmyGN's Avatar
TotaledmyGN
I wouldn't take it to the dealer because most of the dealer recall procedures don't fix the problem and usually involves unneeded/expensive parts. You will end up getting the CLB from Corvettes of Houston anyways. Automatics have a higher success rate with the dealer fix but I still wouldn't do it. Send a private message to 8VETTE7 for some more specific help. good luck
Old Feb 20, 2010 | 08:12 PM
cdkcorvette7's Avatar
cdkcorvette7
IMO... BAD IDEA. They'll perform a recall that has been proven time and time again not to work. My advice would be to purchase a column lock bypass from a forum vendor like corvettes of houston and be done with it. It's a 15 minute install AT THE MOST.
Good luck.
Old Feb 21, 2010 | 08:56 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Forget the dealer "fix". They don't know what they are doing. Buy the Column Lock Bypass from Corvettes of Houston for $45.00. It comes with DIY instructions. You will have it installed in about an hour and your problems are over.
Old Feb 21, 2010 | 09:47 AM
cdkcorvette7
You should fill out your profile so we can tell where you're located. There might be someone close enough to you to give you a hand if you run into trouble with the CLB.
Old Feb 22, 2010 | 09:55 AM
jp101's Avatar
jp101
Cruising
updated forum info. car back home, ordered harness kit from corvettes of houston. thanks everybody !!
Old Feb 22, 2010 | 10:23 PM
abigfoot's Avatar
abigfoot
I did that years ago. If it is still locked turn the key switch on and grab the steering wheel at 10 and 2 and turn the wheel back and forth very fast. This usually will free it up. You can then unplug the col lock mtr. You can then install the col lock setup.
Old Feb 22, 2010 | 10:29 PM
cdkcorvette7
Jarring the steering wheel like that may unlock it, but it isn't necessary. The CLB you purchased should come with a device to unlock the steering column. It's a cord that connects to the harness where you will install the CLB after unlocking the column and it plugs into the cigarette lighter. That will unlock your column so you can install the bypass...
Old Feb 25, 2010 | 07:46 PM
jp101's Avatar
jp101
Cruising
Default crap
CLB came today from corvettes of houston. open up knee panel and found k-harness installed. tried various resetting and called chrisopher at corvettes of houston. pointed to the BCM, removed and open up, found burnt PC board at green plug. Dealer and reprogram???
To steering colum service
