No front bolt=suspension noise
Old Feb 20, 2010 | 12:36 AM
darkstang5887's Avatar
darkstang5887
Default No front bolt=suspension noise
removed my front lowering bolt and my car makes a poping noise on low speed turns.i know its my spring rubbing on my control arm due to there not being a bolt there anymore. what are you guys putting in between there to kill the noise? thanks
Old Feb 20, 2010 | 02:26 AM
HD_2_C5's Avatar
HD_2_C5
PM? Do share the info publicly!! I will be lowering mine on stock bolts and might even remove the front ones. I'd like to know in advance of any possible issues. Thanks!
Old Feb 20, 2010 | 10:08 AM
darkstang5887
Please I know people have been through this before
Old Feb 20, 2010 | 01:27 PM
Its_Go_Time's Avatar
Its_Go_Time
I turned these little insulator pads on a lathe from some nylon we had kicking around. The good thing with these is they won't work themselves free over time, and I could make different thicknesses for each side to level the car out. With that said, I've heard of people using thin, flat pieces of plastic like bondo applicators with good results. I've even heard of people using linoleum. Just bear in mind that when you go this low, the spring itself will start to rub against the arm. Very carefully smooth that area away with a dremel sanding cone, either on the spring or the arm.
Old Feb 21, 2010 | 02:23 PM
darkstang5887
thanks alot go time the bondo applicator worked great
To No front bolt=suspension noise
