Half shaft questions
Old Feb 20, 2010 | 02:13 AM
70 LS1's Avatar
70 LS1
Default Half shaft questions
Hey all, I'm planning my next project and have a few questions about C5 half shafts.
What diameter are they?
Are they steel or some other metal?
I'm pretty sure they are locked in place at both ends (differential and hub) and not slip fit like a drive shaft, so how do they account for suspension travel. With the upper and lower control arms different lengths causing camber gain with suspension travel, I would think there would need to be a way for the half shafts to get longer or shorter as they move up and down.
Old Feb 20, 2010 | 10:19 AM
lionelhutz's Avatar
lionelhutz
The inner CV joint is a slip type joint that allows the length to change.
Peter
Old Feb 20, 2010 | 02:06 PM
70 LS1's Avatar
70 LS1
Thanks, I thought it might be something like that. I must admit, I'm not too familiar with CV joints.
Old Feb 20, 2010 | 04:46 PM
LoneStarFRC's Avatar
LoneStarFRC
Steel shafts. Approx. 1 3/4" diameter. CV joints on each end.
Old Feb 20, 2010 | 09:46 PM
Carcass's Avatar
Carcass
There's a plastic snap ring on them that holds them in the diff-get the top "A" arm loose and give them a good yank and they come right out.
Don't pry them out or you could damage the CV boot,and be slinging grease everywhere .
To Half shaft questions
