C5 Head light noise
Old Feb 20, 2010 | 10:57 AM
Wicked Ride's Avatar
Wicked Ride
Cruising
Default C5 Head light noise
I have a loud grinding noise when I shut of the head lights. They open & close fine except 4 the grinding noise on the passenger side. Any answers would be greatly appreciated. Carl
Old Feb 20, 2010 | 11:51 AM
corvette77's Avatar
corvette77
Your plastic headlight gears are stripped. This is a well known issue with the C5 cars. They make replacement gears made of metal (brass I think) that you can fix it with. Search the forum and you will probably find countless replies to this issue. Mine did the same thing, but was covered under warranty.
Old Feb 21, 2010 | 12:14 AM
sgostisha's Avatar
sgostisha
Default ebay buy
you can pick up the plastic one on ebay for around 15 bucks. I had the same problem and replaced mine in about 45 minutes. didnt see the brass ones but I would bet they are there as well.
Old Feb 22, 2010 | 12:06 PM
YellowOne's Avatar
YellowOne
Navigator
I had one go bad last year. Picked up the brass replacement kits from Rodney Dickman for both sides since I wanted a permanent fix. The first one took a couple hours to take apart and reassemble and I let the epoxy dry overnight. The second one only took a half hour since it was the same process. Both lights now perfect. Excellent instructions with great pictures.
Old Feb 22, 2010 | 04:03 PM
jcs44's Avatar
jcs44
I recently replaced the drivers side with a Rodney Dickman kit that has the metal gear plus the gear lube, epoxy, and a neat strap that helps hold the gear case together. Pretty easy to do, but it does take some time to get the headlight assembly out and back in again. Be sure to let the epoxy dry overnight per the instructions. Mine had been repaired before and the epoxy job was poorly done and the cover came loose from the gear case which allowed the gear to flop around when under torque from the motor. It made the same noise as described but was not stripped. By all means fix it yourself.
jcs44
Old Feb 22, 2010 | 07:13 PM
Wicked Ride
Cruising
I'm new hear & I want to thank everone on the quick replys of my problem.
I ordered both gears from Rodney Dickman yesterday. He confirmed they were shipped today. Thanks again for all your help. Great Site.
Old Feb 28, 2010 | 09:26 AM
Wicked Ride
Cruising
Both headlight gears are replaced & working great. Can't thank you enough for all your help. Thanks again Carl
To C5 Head light noise
