HELP! fuel pump went out
Old Feb 22, 2010 | 09:09 PM
markoo's Avatar
markoo
Default HELP! fuel pump went out
:ack The fuel pump in my 2000 suburban crapped out. $1000 to have it fixed. ? Can I cut the fuel line and put a electric pump in-line ???????
Will it suck fuel though the pump in the tank & have enough pressure to work. Thank you for your input,
Mark
Old Feb 22, 2010 | 09:33 PM
abigfoot's Avatar
abigfoot
Mark
NO! Make sure they put a Factory pump in, or you will be doing it again in a year. They cost more but they work.
Old Feb 22, 2010 | 09:35 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Why not do it yourself?? Its not that hard.
Old Feb 22, 2010 | 10:09 PM
jordan89's Avatar
jordan89
$1000 is way too much!!!! My brother and I just changed the fuel pump on my dad's '02 Yukon XL and it only took us about an hour or so. Do it yourself and save $800 dollars. The pump shouldn't cost more than $200.
To HELP! fuel pump went out
