I'm getting a set of c6 factory 19/18 wheel set this weekend. can someone tell me what it takes to get them mounted on my 98vert? I have read that i need a spacer for the rear. can anyone tell me what size and what all i need to make this work...
if you see a button labeled "search" i would suspect that you can, in fact, use it to find answers to common questions. since just about everyone changes the wheels on their corvette, it's probably not a bad assumption that this might be a common question and thus use the search feature
You may need a 1/4 inch spacer or the rear wheels but, in most cases, it is not necessary. Try mounting the rears to check if they rub the wheel wells. If the do, you will need a spacer.
