Targa top white streak
Old Feb 25, 2010 | 08:37 AM
317nathan's Avatar
317nathan
Default Targa top white streak
I have reviewed all the post and the how to for refinishing the targa clear top. I have just the evil white mark above the passengers head and the rest looks pretty good.
If I follow one of the many threads on this will that get my white streak?
Is the streak in the top coat or?
Sorry if I am beating a dead horse just want to check before I go and start sanding.
Thanks.
Old Feb 25, 2010 | 10:19 AM
jedblanks's Avatar
jedblanks
You'll probably have to sand the entire top to make it look right. If you aren't experienced with refinishing surfaces (as I wasn't) it will probably turn out ok, but not as good as the thread shows.
Old Feb 25, 2010 | 12:29 PM
317nathan's Avatar
317nathan
Thanks, just OK will look better that this big white stripe!
Old Feb 27, 2010 | 09:02 PM
lionelhutz's Avatar
lionelhutz
There is a hard coating on the top. It is what is peeling. I sanded mine with a dual action sander and then had my buddy clear coat it. It could use a wet sanding but it has a solid black look and it's holding up. Before the clear-coat, it showed a lot of scratches but that is OK because they disappear once it was coated.
Peter
Old Mar 1, 2010 | 10:07 AM
317nathan's Avatar
317nathan
Wow that was a lot of work. I sanded it down and painted the entire thing with clear coat, I am letting it dry and will try buffing it out later.
Thanks for your help.
To Targa top white streak
