Explain resetting shift points to me, please
Old Feb 25, 2010 | 03:58 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Explain resetting shift points to me, please
Finally picked up a 3:42 dif for my 97 A4 with 2:73 diff. I have tried in my head to resolve this condition, but I get hung up. Exactly what is the situation with rpms, etc? There are 3 parts that are revolving per minute...the trans, the engine, and the diff. I understand the newer diff will turn faster, but after that I get confused....thanks
Old Feb 25, 2010 | 04:22 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Actually the new differential (3.42) will turn SLOWER per engine rpm than the old (2.73). 3.42 means that for every one revolution of the tire, the input to the differential must turn 3.42 times. To get the same one revolution of the tire with the 2.73 the input only has to turn 2.73 times.
Another way, if the transmission is in a direct drive (1:1) gear, which I believe is 3rd in the auto, the engine will turn 3.42 times to get the tire to revolve one full revolution.
Old Feb 25, 2010 | 04:41 PM
chaase's Avatar
chaase
St. Jude Donor '12
The short answer is that for the same engine RPM, the cars speed will be lower using 3.42 gears compared to 2.73.
Given that fact, the transmission needs to be given new instructions on shifting. I believe the computer has tables and for a given gear, there is a speed and engine RPM range that dictates when to shift.
Old Feb 25, 2010 | 06:59 PM
HowlinC5's Avatar
HowlinC5
with HP Tuners or a hand held there is a selection for gear ratio, once you change that the computer takes care of the rest.
Old Feb 25, 2010 | 08:00 PM
$$$frumnuttin'
Ok, I had it backwards...so, this means without adjusting shift points, the car will REV higher than it should before the trans shifts, correct? Also, MPH (speed) will be higher for a given engine RPM, and that is where the increased torque comes from, right?
Old Feb 25, 2010 | 08:18 PM
Mark C5's Avatar
Mark C5
No, speed will be LOWER for a given rpm. The engine must turn a higher rpm to get the tires to turn the same.
The computer takes more into consideration than rpm for determining shift points. It uses vacuum, vehicle speed, throttle position and rpm. As said before, most tuners have tables for different gear ratios.
Old Feb 25, 2010 | 09:08 PM
$$$frumnuttin'
Like I said, I have a tough time understanding what is actually happening. I am aware computers can deal with it, I just want to understand the mechanical engineering of it all....so, if the engine turns at a higher RPM to get the same revolution for the rear wheels, what accounts for the shorter times in the quarter mile?
Old Feb 25, 2010 | 09:27 PM
HowlinC5's Avatar
HowlinC5
This seems more complicated than it should. If a 3.42 has a lower top speed than a 2.73 it seems to me that the engine would over rev between shifts not under rev. The 3.42 require less motion to acheive a given speen than the 2.73. To put it simply your 0-60 time will decrease with the 3.42. So I don't see how the engine has to turn more times to rotate the axle if it makes the car faster.
Wheres lucky131969?
Old Feb 25, 2010 | 10:12 PM
Mark C5's Avatar
Mark C5
It's about torque multiplication. The 3.42 requires less torque to attain a given rpm than the 2.73, therefore the engine will attain a given rpm quicker with the 3.42 than the 2.73 resulting in a faster acceleration for a given distance. A higher (numerically) ratio will out accelerate a lower (numerically) ratio. It's all about acceleration, not top speed.
Old Feb 25, 2010 | 10:38 PM
Mark C5's Avatar
Mark C5
This is incorrect. The 3.42 will require a higher input speed (rpm) than the 2.73. Remember, the designation number (ratio) indicates how many times the input shaft must make a full revolution to cause the output shaft to rotate once. A 3.42 ratio differential must have it's input shaft turned 3.42 times for the output to rotate one revolution.
Old Feb 25, 2010 | 11:56 PM
byronhunter's Avatar
byronhunter
Wheres lucky131969?
Someone talked ugly to him, so he went to bed!!!!!!!!!
MarkC5 got it right.
Old Feb 26, 2010 | 12:05 AM
HowlinC5's Avatar
HowlinC5
Cool, at least someone did. Still doesn't make sense to me, the physics that is.
Old Feb 26, 2010 | 12:07 AM
HowlinC5's Avatar
HowlinC5
I knew one of you would be all over this! You guys have helped me more than once, and I thank you.
Old Feb 26, 2010 | 11:32 AM
$$$frumnuttin'
Ok, we are getting closer here So, what about the shift points? Let's put it this way:
If I switch to 3.42 and do not adjust shift points, exactly what will happen as far as MPH at each gear? Versus the illusive adjustment? A chart would really help!
Old Feb 26, 2010 | 01:18 PM
HowlinC5's Avatar
HowlinC5
Your shift points will be fine you just aren't going to know how fast you are going until the computer has the correct gear ratio in it.
Old Feb 26, 2010 | 01:36 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Wrong, in fact, it's the exact opposite.
You can change the gears to whatever you want, the PCM still knows how fast the car is moving since it senses axle speed. You do not need speedometer correction for a gear change on a C5.
The A4 shift correction is usually needed because the PCM usually commands upshifts at specific MPH points, not RPM. The gear change obviously does change the RPM/MPH ratio.
So, for example (numbers pulled out of the air, this is just an example)...Say your 2.73 car is programmed to upshift from 1st to 2nd gear at 46mph when WOT, you will find the engine near 6000RPM at this point.
Now, adding the 3.42 gears means your engine is now at a higher RPM for any given vehicle speed. So you now try to accelerate, and all of a sudden you find yourself hitting the 6200 rev limiter and engine power is being cut before reaching the 46mph commanded shift point. Trans never gets the command to shift because the MPH hasn't been reached, and you won't reach the MPH because the rev limit won't allow it. The conflict there becomes quite obvious.
This is a greatly simplified explanation, but is enough to show why shift points need to be adjusted when changing gear ratio on A4 cars.
Old Feb 26, 2010 | 01:42 PM
HowlinC5's Avatar
HowlinC5
Now see thats a good simple explanation. Thats good to know.
To Explain resetting shift points to me, please
Old Feb 26, 2010 | 02:14 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What is there to understand? in vs out. simple as that. 2.73 turns of input used to = 1 turn of output. now 3.42 turns of input = 1 turn of output.
Old Feb 26, 2010 | 05:10 PM
Humy's Avatar
Humy
I think I have gone cross-eyed
Old Feb 26, 2010 | 06:21 PM
$$$frumnuttin'
Thanks Bro...now I get it. So, if needed I could limp home and use a hypertech to adjust the points. So, should I try to match the same shift MPHs I had with the 2.73? Does a dyno tune accomplish the same thing and optimize power through all the gears?
