Help with codes!
Old Mar 9, 2002 | 04:34 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Help with codes!
What do these mean, I'm still a newbie to the C5 world.
10 PCM 1 CODE
BORFA 2 CODES
The car will shift very hard, and once I dump these codes all is well and smooth shifts again. They won't show up again unless I'm aggressively manually shifting the A4 like in a race.
Am I hurting the car?
Thanks again.
Old Mar 9, 2002 | 07:59 AM
Z06 Quin's Avatar
Z06 Quin
Default Re: Help with codes! (TexCorvette)
https://www.corvetteforum.com/techti...D=26&TopicID=1 :cheers:
Old Mar 9, 2002 | 03:39 PM
TexCorvette
Default Re: Help with codes! (PoBoy Racer)
IF BORFA is a section, how do I see the two codes within it? I couldn't find BORFA explained in that link other than remote body function?
Old Mar 9, 2002 | 07:47 PM
Z06 Quin's Avatar
Z06 Quin
Here are the codes for B0 RFA.......do you know how to poll the codes???
B0 RFA Remote Function Actuation page 8-676
B0605 Receiver Internal memory malfunction -RFA
B2805 No Transmitters Programmed -RFA
C21 00 Left Front TPM Sensor Malfunction -TPM
C2105 Right Front TPM Sensor Malfunction -TPM
C2110 Right Rear TPM Sensor Malfunction -TPM
C2115 Left Rear TPM Sensor Malfunction -TPM
C2120 TPM System malfunction (No Sensors Received -TPM
C2121 TPM System Programming malfunction (No Sensors Programmed)-TPM
U1000 Loss of Communication Undetermined -RFA
U1016 Loss Of Communication with PCM (No SOH Message Received -RFA
U1064 Loss Of Communication with DCM (No SOH Message Received -RFA
U1096 Loss Of Communication with IPC (No SOH Message Received -RFA
U1255 Serial Data Line Malfunction -RFA
Old Mar 10, 2002 | 03:04 AM
TexCorvette
OK, the BORFA was the tire sensors then. I know how to get to manual dyno and scroll through the sectioins and once I see the number of codes, how do I go into that section to get the specific code?
Old Mar 10, 2002 | 12:35 PM
K&B Motorsports's Avatar
K&B Motorsports
Use the number 2 and 3 buttons from the top to scroll up and down through the individual code in the sections.
To Help with codes!
