Undrive Pulleys worth it?
Old Mar 9, 2002 | 04:39 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Undrive Pulleys worth it?
Look to squeez another 3-4 tenths to get in the 11s. Will this or any other simple bolt on get me there?
Old Mar 9, 2002 | 07:22 AM
Z06 Quin's Avatar
Z06 Quin
Default Re: Undrive Pulleys worth it? (TexCorvette)
3:73's should :cheers:
Old Mar 9, 2002 | 08:51 AM
vstella's Avatar
vstella
Tex Corvette...I'm in the same place..low 12's.I just rebuilt my A4 transmission...and new 3000 stall converter.It feels like another .1-.2 there but I think it's going to take a cam :rolleyes: Just my .02
Old Mar 9, 2002 | 10:03 AM
jefffxdwg's Avatar
jefffxdwg
Not a simple bolt on, you have to remove the steering rack. I would only do it if the car was apart for say.... a cam install.
Old Mar 9, 2002 | 03:34 PM
TexCorvette
Default Re: Undrive Pulleys worth it? (jefffxdwg)
pulleys not even worth 2 tenths? I would love to have MTI redo my heads, but not ready for that. Just looking for a few tenths, and my rear is already upgraded, not looking to go steaper with my 3500 stall.
Old Mar 9, 2002 | 03:37 PM
Untouchable00's Avatar
Untouchable00
Try some headers.
Old Mar 9, 2002 | 03:54 PM
C54TIM's Avatar
C54TIM
I'd say it's a good mod if your putting heads, cam, and headers in. You get the labor for free. But just to add it, I'd pass.
You might want to think about 1.8 rockers, that will give you a little exptra HP.
It might get you 2 tenths! Tuff call though.
[Modified by C54TIM, 11:55 AM 3/9/2002]
Old Mar 9, 2002 | 04:09 PM
TexCorvette
Default Re: Undrive Pulleys worth it? (Buckmaster)
Ok, thanks. So I'm out of cheap or easy HP now? Was lots of cheap and easy gains out of my L98 :(
BTW, where you get your hood mat painted! Looks great! How much are the ARE stage two heads, and where can I read about it online? I was looking into the MTI stage one at a 95HP gain!! :eek:
[Modified by TexCorvette, 3:12 PM 3/9/2002]
Old Mar 9, 2002 | 06:09 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Undrive Pulleys worth it? (PoBoy Racer)
No, it will not, Only if you do heads and cam, then do the pulley! ong tube headers and 3.73 for sure!
Old Mar 9, 2002 | 07:09 PM
Joel Fromkin's Avatar
Joel Fromkin
Get NOS and run in the 11's. I put nos on my 2000 C5 at 5 thousand miles. Traded the car in with 60 thousand miles. I went thru a bottle a week. You have to change to NGK plugs and thats it. With a 100 shot the car went 11:88 on the run flats. Never had a problem with the engine. I wouldn't run more than a 100 shot unless you are going to do other modifications. If you keep an eye on the bottle pressure and just use a 100 shot, you'll never have a problem. I now have the "juice" on my 2002. :cheers: :seeya :seeya
[Modified by Joel Fromkin, 5:10 PM 3/9/2002]
Old Mar 9, 2002 | 07:21 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Undrive Pulleys worth it? (Joel Fromkin)
UD pulley = 10 rwhp cost $220
LT headers & X pipe = 12.4 rwhp cost $1100
UD pulley install $200
LT headers $ x pipe install $300
To Undrive Pulleys worth it?
