Oil Pressure - Quick Question
Old Feb 26, 2010 | 09:15 AM
tonylukes3's Avatar
tonylukes3
Default Oil Pressure - Quick Question
Morning all,
After searching around, I can't seem to locate what the normal range for the oil pressure to be in the C5's. Mine is hitting around 40psi at cruising speed, and 30psi at idle. Is this a safe range to be in?
Thanks!
Sal
Old Feb 26, 2010 | 09:28 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
10psi/1K rpm's is the "old school" rule. so yea, that's plenty
Old Feb 26, 2010 | 09:38 AM
dougbfresh's Avatar
dougbfresh
Originally Posted by tonylukes3
Morning all,
Thanks!
Sal
Why would you think it's not?
Old Feb 26, 2010 | 09:39 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
yeah i can't imagine why you wouldn't think being in the dead middle of the gauges range while going down the road is abnormal.. but to each his own i suppose
Old Feb 26, 2010 | 09:47 AM
tonylukes3's Avatar
tonylukes3
Thanks. It was more of the idle drop in pressure to 30 that I was curious about, not the cruising speed pressure.
Old Feb 26, 2010 | 09:48 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
gotcha. 30 at idle is pretty good. i've seen less.
Old Feb 26, 2010 | 10:43 AM
tonylukes3's Avatar
tonylukes3
Cool, thanks
To Oil Pressure - Quick Question
