Crash Bolts?
Old Feb 26, 2010 | 11:25 AM
TedDBere's Avatar
TedDBere
Default Crash Bolts?
Do C5s have GM authorized (service manual or service bulletin described) crash bolts that can be used to get more camber in the front?
Old Oct 22, 2011 | 08:59 AM
TedDBere's Avatar
TedDBere
OK, now that SCCA has updated the stock rules to allow these bolts, I'll ask the question again.
Old Oct 22, 2011 | 01:36 PM
Lothar34's Avatar
Lothar34
Have you looked at the front suspension?
Old Oct 22, 2011 | 02:45 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Camber, caster, toe and ride height are adjustable.
Old Oct 22, 2011 | 04:38 PM
Lothar34's Avatar
Lothar34
^^This. There is no place to put a crash bolt with our double-wishbone setup. And you already have more camber adjustment than probably anything out there.
Old Nov 8, 2011 | 04:50 PM
TedDBere's Avatar
TedDBere
I'm already maxed out in Camber and I'd like to legally get more. The SCCA just updated their rule book to allow the use of crash bolts to gain additional camber, if it's mentioned in the service manual or a tech update by GM.
Old Nov 8, 2011 | 07:03 PM
LoneStarFRC's Avatar
LoneStarFRC
Might try calling Pfadt Racing and asking them. Couldn't hurt.
Old Nov 8, 2011 | 07:13 PM
lionelhutz's Avatar
lionelhutz
Where do you expect a part used on a strut suspension to go when you have a LSA suspension?
Old Nov 8, 2011 | 10:37 PM
Lothar34's Avatar
Lothar34
Crash bolts are not mentioned in the service manual or any tech updates for the Corvette. I can promise you that.
Old Nov 9, 2011 | 06:25 PM
Pfadt Racing's Avatar
Pfadt Racing
There is already a pretty broad range of Camber adjustment in the front of the Corvette... I don't imagine that GM actually manufactured a second set of eccentric bolts for cars that had seen crash damage. Unfortunately I think you might be out of luck on this one.
Old Nov 10, 2011 | 01:35 PM
argonaut's Avatar
argonaut
I'm assuming the OP, in using the term "crash bolt", is referring to replacements for the two bolts that hold the front lower A-arm to the cradle that have eccentric adjusters on them (and possibly also the one bolt on the rear A-Arms that is adjustable).
FWIW, when I first read "crash bolt" I instantly thought of a Mac-Sturt front suspension like on a Mustang, where you have two bolts that hold the strut to the knuckle. In this context "Crash bolts" are either smaller in diameter than OEM or are ecentric. The idea being to give you some ability to adjust the relationship of the strut to the knuckle (i.e. adjust the camber). I think some of the other folks who posted thought the same thing.
Old Nov 10, 2011 | 02:44 PM
Russ K's Avatar
Russ K
Remove the flat washers that are located between the upper A-arms and the frame to get more negative camber.
Russ Kemp
Old Nov 10, 2011 | 06:37 PM
lionelhutz's Avatar
lionelhutz
The C5 with it's aluminum suspension parts and built-in adjustability would really have to be fixed properly after an accident at which point a street alignment would easily be possible. I would not feel safe driving a C5 that had a straightened crossmember or tweeked suspension parts.
To Crash Bolts?
