Gear shift rattle
Old Feb 27, 2010 | 01:02 AM
High Tide's Avatar
High Tide
4th Gear
Default Gear shift rattle
New to the forum & need some help: My 2001 Coupe 6 speed has a very noticable rattle, under acceleration, in the shift lever. The rattle starts after the car has been driven for approximately 1-1/2 hrs. A slight pressure on the shifter will stop the rattle. The car has 41000 miles and not driven hard. Has anyone else had this problem?
Old Feb 27, 2010 | 03:53 AM
LoneStarFRC's Avatar
LoneStarFRC
It sometimes occurs with aftermarket shifters.
Old Feb 27, 2010 | 12:06 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
My Hurst does the same thing. Started about a year after I installed it. The bushings that hold the shifter assembly down were worn so I'll be replacing this this spring and adding blue locktite.
Hopefully that will quiet it down.
Old Feb 27, 2010 | 12:20 PM
LoneStarFRC
The particular choice of ***** can also be a factor. Some are more prone it seems, than others.
Old Feb 27, 2010 | 12:46 PM
Blue 92's Avatar
Blue 92
Same **** since I did the install. Hurst ball.
Old Feb 27, 2010 | 01:09 PM
High Tide's Avatar
High Tide
4th Gear
Thanks for the replies. Maybe I should have stated that it is a factory shifter. I do have an aftermarket shift **** (ball) and it seems tight, but I think I'll remove it and see if the noise continues. Any other ideas would be greatly appreciated.
Old Feb 27, 2010 | 01:10 PM
Patches's Avatar
Patches
For aftermarket shifters, I have always used a Fernco rubber pipe cap tho quell the vibrations that can happen when you install a Hurst, Ripper or MGW shifter. My aftermarket shifters have never suffered from those types of vibrations since I installed one of these. A forum member posted this here long ago so I don't remember who to give credit to. The cap can be bought at Lowe's/HD.
Here's my current MGW
With the Fernco cap
The cap - I use the 1-1/2" version. I used this 2" version when I tried the C6 shifter.
Old Feb 27, 2010 | 01:23 PM
Blue 92's Avatar
Blue 92
Thanks.
I'll try adding one when I open it up to do the bushings.
To Gear shift rattle
