Head light buckets won't go down.
Old Mar 9, 2002 | 02:06 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Head light buckets won't go down.
Went out with SBKIM and Tattooed last night, weather dropped about 40 degrees after raining and now my head lights (2001 Coupe) won't return to the rest position? Any suggestions about frozen parts or guides? Or do I get to see my friendly dealer again?
Old Mar 9, 2002 | 02:12 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Head light buckets won't go down. (JoeyG)
"Any suggestions about frozen parts or guides?"
I have not seen any problems due to frozen parts :D
Old Mar 9, 2002 | 02:45 PM
c54dan's Avatar
c54dan
Had the same problem with my 98 a few years back. The relay that controls the buckets is in front of the passenger side bucket. Seems mine had a small crack in the relay and water got in there, shorted it out. Check that first...
Dan
Old Mar 9, 2002 | 03:00 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Head light buckets won't go down. (c54dan)
C54DAN has a good point :yesnod: I have seen a few headlamp control modules fill up with water,shorting them out.A telltale sign is a nasty electrical odor from under the right side headlamp assembly (let the smoke out)
You have a faulty module or upstream,because after the module the headlamps are on seperate circuits
Old Mar 9, 2002 | 03:20 PM
JoeyG's Avatar
JoeyG
Default Re: Head light buckets won't go down. (C-5 TECH)
Thanks for the replies :cheers: , time to visit my friend Shawn at the delear service department.
To Head light buckets won't go down.
