calipers
Old Mar 1, 2010 | 04:08 PM
tmccollu's Avatar
tmccollu
Default calipers
Will stock c5 calipers from the front fit the rear they appear larger.
Old Mar 1, 2010 | 05:11 PM
jrose7004's Avatar
jrose7004
They are bigger so I wouldn't think they would.
Old Mar 1, 2010 | 06:57 PM
Its_Go_Time's Avatar
Its_Go_Time
They will definitely bolt up, but unless you put the front rotors on, whats the point? If you put the front rotors on the rear, you'll loose the parking brake. I suppose that the balance between the front and rear braking forces would also go out the window if you use the same size brakes all around?
To calipers
