EMERGENCY: Zero Oil Pressure
Old Mar 9, 2002 | 07:49 PM
magnetic1's Avatar
magnetic1
Default EMERGENCY: Zero Oil Pressure
A friend's Vette has ZERO oil pressure reading on the gauge. Checked the oil, and there is oil there.
No codes have been set though...
Thinking bad sender or pump perhaps?? Any insight is appreciated....
Old Mar 9, 2002 | 09:14 PM
Gunny's Avatar
Gunny
Default Re: EMERGENCY: Zero Oil Pressure (magnetic1)
I don't know what year it is... but if it's under warranty I'd have it flat-bed-trucked (tow it up with winch, don't drive it up) to a good, competent shop.
It could be a clogged or failed oil pump, the sending unit, or computer glitch.... or a combination of all 3. I wouldn't mess with it, unless he's got a cherry picker and likes yanking engines, dropping oil pans and playing under the car. Just my .02. Tell him good luck -- and to NOT run the car until the problem's identified. :cheers:
Old Mar 9, 2002 | 09:21 PM
Flintstone's Avatar
Flintstone
Default Re: EMERGENCY: Zero Oil Pressure (Gunny)
Is this right at startup?
Does it regain oil pressure if he 'blips' the throttle at idle?
Is there an associated "low oil pressure" warning on the DIC accompanying the guage reading?
Could be the sensor, but could also be a stuck oil pump pressure relief valve. Had that happen to me last year and GM bought me a new engine.
Don't drive it either way until you figure it out.
F
Old Mar 9, 2002 | 10:24 PM
MDT's Avatar
MDT
magnetic1,
As others pointed out....don't drive it. Have it flat bedded to the shop. They can hook up an auxilliary oil gauge and see if there is any pressure. There have been numeous posts of oil pump check valves sticking in the open position and causing no oil pressure. Probabably will turn out to be the sending unit, but can't take the chance.
Good luck to your friend.
Mark
Old Mar 10, 2002 | 12:17 AM
magnetic1's Avatar
magnetic1
Default Re: EMERGENCY: Zero Oil Pressure (MDT)
Where is a place to plug the mechanical gauge??
Old Mar 10, 2002 | 12:19 AM
C5 Hardtop's Avatar
C5 Hardtop
known problem :(. There is either a) something wrong with the oil sensor or b) the oil pump.
Don't start it again, don't drive it. Take her in and have it fixed before more damage comes along.
Joel
To EMERGENCY: Zero Oil Pressure
