Cove LED Blinker Wiring?
You could just tap the front turn signals in the front too...
I also have a second light strip in each cove that run with the tail lights. Thats two separate strips in each cove.
Where did you get your lighting? I plan on doing the rear vents as well but those will be both brake and flasher.
C209
C209 (23 cavities)
Instrument panel harness to steering column harness, LH side of the steering column, attached to the lower instrument panel bar - headlamp and turn signal switches
Connector Part Information
12092249
23-Way F Metri-Pack 280 Series (BLK)
12092248
23-Way M Metri-Pack 280 Series (BLK)
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A
A
WHT
27
Hazard Flasher Output
B
B
DK GRN
19
Stop/Turn Lamp Feed-RR
C
C
YEL
18
Stop/Turn Lamp Feed-LR
D
D
PPL
16
Turn Signal Flasher Output
E
E
Not Used
F
F
DK BLU
15
Turn Signal Lamp Feed-RF
G
G
LT BLU
14
Turn Signal Lamp Feed-LF
H
H
DK BLU
38
Cornering Lamp Control Feed
J
J
BLK
58
Cornering Lamp Feed-Right
K
K
LT GRN
11
High Beam Headlamp Feed
L
L
TAN
12
Low Beam Headlamp Feed
M
M
Not Used
N
N
BLK
150
Ground
P
P
Not Used
R
R
BRN
9
Park Lamp Feed
S
S
WHT
103
Headlamp Switch Signal-"On"
T
T
DK GRN
306
Headlamp Switch Output-"Off"
U
U
ORN
57
Cornering Lamp Feed-Left
V
V
BLK
28
Horn Relay Output
W
W
RED
842
Battery Positive Feed
X
X
RED
842
Y
Y
LT BLU
74
Park Lamp Switch Output
Z
Z
ORN
240
You can paint the engine block off panels silver also to get a glow thats a bit brighter then that.
I made my own panles like DIYguyshows on Oznium's site;
http://www.oznium.com/corvette_LED_shark_gills.php
Tim
