rear lower ball joint stud
Old Mar 7, 2010 | 06:06 PM
daleweible's Avatar
daleweible
Default rear lower ball joint stud
I replaced a wheel bearing & hub today, in reassembly I have a problem with the lower ball joint stud torning. Have tried to amke 2 different allen wrenchs to hold the stud but no luck. dont know if someone has another method, there is such limited space under the cv that by the time I some of the allen head off and clean the end up square again the 2 tools are not working// I though i may have to assemble, get enough weight on it to seat the ball joint stud then un assembly to finish tighting it? I am right at the taper of the stud.
Old Mar 7, 2010 | 07:27 PM
Its_Go_Time's Avatar
Its_Go_Time
Like you mentioned, I'd try jacking the arm up to try and seat the stud a little. It can be pretty stubborn sometimes, and I ended up making a little tool to hold the stud. I bent up a piece of 1/8 x 1 steel strapping, and welded on a little piece of allen key. Not pretty, but it works!
Old Mar 7, 2010 | 07:52 PM
daleweible's Avatar
daleweible
so are making these for sale? Only owning a corvette would make some go to that effeort. between spec's to see and getting light to see I'm tired. I dont weld either. You can only hit aluminum so hard!!!!!! My first was a 69 that was a major job to replace the rear wheel bearings, this one went smooth to this point. I'm to old for this!!!!
Old Mar 7, 2010 | 10:06 PM
lionelhutz's Avatar
lionelhutz
Try strapping the upright (or spindle or whatever you want to call it) to the base of the floor jack and then jacking under the lower ball joint to force it into the socket. This will easily get you enough force pressing it into the upright that it will quit turning and you should have no trouble tightening it.
Peter
Old Mar 8, 2010 | 07:32 AM
daleweible's Avatar
daleweible
Thank you that sounds good.
Old Mar 8, 2010 | 11:28 AM
postwhore's Avatar
postwhore
Air gun would snug it right up
Old Mar 8, 2010 | 12:49 PM
lionelhutz's Avatar
lionelhutz
There is no room for an air gun.
Peter
Old Mar 8, 2010 | 12:55 PM
MySR71's Avatar
MySR71
I cut off part of my allen wrench just after the 90deg bend. It just fit as I recall.
Old Mar 8, 2010 | 06:09 PM
daleweible's Avatar
daleweible
You had the right solution. Made it a 10 minute fix, thanks again
Old Mar 8, 2010 | 06:13 PM
daleweible's Avatar
daleweible
Thanks for all of the replys, but our friend from canada had the fix, a strap over the top of the spindle attached both ends to the bottom of the jack loaked and snugged the stub into the taper and bing the lower ball joint is done. I had tried 2 different cut down allen wrenchs and either had to much or not enough, spent a day doing that. The strap works.
Old Mar 8, 2010 | 09:29 PM
postwhore's Avatar
postwhore
Peter
huh ?
I've done it
use an impact swivel
Old Mar 8, 2010 | 09:45 PM
Its_Go_Time
huh ?
I've done it
Huh?
There's about 1/4 inch between the CV joint and the top of the stud.
That's a pretty magical swivel.
Old Mar 9, 2010 | 02:46 AM
postwhore's Avatar
postwhore
Crap , I did it when the CV was out
you are right
To rear lower ball joint stud
