Ignition Solenoid Going out?
Old Mar 8, 2010 | 12:10 AM
BIGTACO's Avatar
BIGTACO
Default Ignition Solenoid Going out?
So sometimes when I put the key in the ignition and turn the car will not start. It doesn't do any noises or anything strange, it just won't start. So I take the key out , then put it back in, turn it a couple more times and it starts right up.
This a very sporadic and doesn't happen all the time but is beginning to happen more often now. My buddy says that it could be my ignition solenoid going out.
What do you think??
Old Mar 8, 2010 | 12:13 AM
lucky131969's Avatar
lucky131969
What do you think??
pull your codes....
Old Mar 8, 2010 | 09:57 AM
BIGTACO's Avatar
BIGTACO
Originally Posted by lucky131969
pull your codes....
Will do...
Old Mar 8, 2010 | 09:20 PM
BIGTACO's Avatar
BIGTACO
Pulled Codes and thay are all history codes.
I wrote them all down.
B0521H Tachometer Signal Circuit Malfunction
U1160H Loss of Communications with LDCM
B2282H Battery #1 Fault
B2284H Battery #2 Fault
B2285H Battery #2 Fault
B2283H Battery #1 Fault
B2265H Horizontal Position Sensor Fault
None seem to be related to this problem.
"Things that make ya go hmmmm"
Old Mar 8, 2010 | 09:21 PM
postwhore's Avatar
postwhore
so change the solenoid
Old Mar 8, 2010 | 10:23 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Use a volt meter and meaure the battery voltage with the ignition turned off. You need a minimum of 12.5vdc for things to work. When you are turning the key, what happens with the security light in the IP Cluster?
Old Mar 9, 2010 | 09:44 AM
mmartinez's Avatar
mmartinez
Default Solenoid going bad?
I always advise people to clip a DVM to switch post on solenoid and verify 12 volts is present when you turn the key to start the car. If no voltage then problem is upstream, ignition switch going bad maybe,could be your contact area on you key is dirty, if voltage is present it could be your solenoid or starter is going bad. Hope this helps.
To Ignition Solenoid Going out?
