Abs - traction control issues
Old Mar 9, 2010 | 06:17 AM
Doug O's Avatar
Doug O
Default Abs - traction control issues
I test drove a 2001 vett last night. The service abs and servisc the
traction control warning came on. We read the owners manual. It said to stop , turnoff the car. We did for 1 min. re started and no warnings.
The wife and I are thinking about buying this vett. What concerns should we have about these warnings coming on.
Doug O
Old Mar 9, 2010 | 10:57 AM
Venomous's Avatar
Venomous
Hey man, it is USUALLY a familiar problem with Vettes (C5) where there are multiple connectors to the wheel hub to the ABS computer and the connectors (male/female prongs) are a poor design and often have a weak connection that can be lost when hitting a bump and will immediately set off the ABS/TRACTION CONTROL warning light. Also if aftermarket wheels have been put on check the wiring as it often gets chaffed by the tire/wheel.
Old Mar 9, 2010 | 10:58 AM
dougbfresh's Avatar
dougbfresh
Dump the codes from the computer and search here for their meaning(s).
Old Mar 9, 2010 | 11:03 AM
mizenermotorsports's Avatar
mizenermotorsports
7th Gear
mutiple known issues with wireing as well as Electronic Brake Control Module.
If you see a light on a test drive that owuld be fair enough worning to stay away from that one for me.
I've been chasing down my problem for 4 years without success.
Old Mar 9, 2010 | 12:40 PM
BigGun's Avatar
BigGun
Doug O
Something will need to be repaired or replaced. It could be simple and cheap or a pita and expensive. You should pull the codes using the DIC and see what comes up. If you do not know how to do this, find someone who knows these cars to help you. The Vette is a great car but if you don't know these cars and what to look for you can really get screwed. B\\G
Old Mar 9, 2010 | 12:50 PM
lucky131969's Avatar
lucky131969
Doug O
Move on....some problems are hidden until after you buy the car.....this one is in your face......
Old Mar 9, 2010 | 07:25 PM
csc67's Avatar
csc67
Doug O,
Do you know how to retrieve the codes from the car?
List year of car and the codes
There are many ABS/traction control experts as this is fairly common
As already stated - Could be FREE or could be $2K
To Abs - traction control issues
