Rhino Ramps?
Old Mar 10, 2002 | 05:40 PM
BIG Dave's Avatar
BIG Dave
Default Rhino Ramps?
It's time for my first oil change in the C5. I check out several sources on the www for information such as:
http://www.c5-corvette.com/oil_change_procedure.htm
http://www.yellowc5.com/oilchange.shtml
The recommended way to lift the front end appears to be with "Rhino Ramps". So I pick up a pair at Pep Boys for $30. Hey! There's a C5 right on the wrapper so they must work! I get them home and guess what. They don't work. I can't get them pressed against the leading edges of the front tires because the spoiler gets in the way. I suppose I could take off the left and right sides of the spoiler but nobody mentioned that in those attached DIY links and the picture of the C5 on the wrapper shows a C5 up on the ramps with the spoiler still on. Did anybody else have this problem? Is there some step I missed? Thanks!
[Modified by BIG Dave, 4:51 PM 3/10/2002]
Old Mar 10, 2002 | 05:49 PM
Patches's Avatar
Patches
Default Re: Rhino Ramps? (BIG Dave)
Actually, if you feel the air dams, you'll notice how soft and almost rubbery they are. I never hurt them with my Rhino Ramps. BUT, if your car is lowered, you'll need to use a couple of 2x10's as "pre-ramps" to get the fascia high enough to clear the air dams. I had to with my car lowered 1". Some here have even built custom angled pre-ramps to fit the Rhino's.
Old Mar 10, 2002 | 06:18 PM
JT-C6's Avatar
JT-C6
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Default Re: Rhino Ramps? (Patches)
I have the Rhino ramps too and saw the C5 on the packaging. Yes, you must allow the spoilers to bend. There is no damage in doing this. I've put the car up on ramps a zillion times. The spoilers just spring back into place.
Old Mar 10, 2002 | 06:23 PM
luvinc5's Avatar
luvinc5
I don't like the idea of the black rubber spoiler bending but it will flex back into shape. I wish I had the chump change to buy a lift.
Old Mar 10, 2002 | 06:41 PM
97silverbullet's Avatar
97silverbullet
Default Re: Rhino Ramps? (luvinc5)
What they said. I thought the same thing when I bought mine, BIG Dave.
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Yup, I have to do this also to get my jack under the rear crossbeam! :cheers:
Old Mar 10, 2002 | 10:02 PM
michaeld01c5's Avatar
michaeld01c5
Default Re: Rhino Ramps? (DAVS Y2K)
If I worried about the spoiler scaping anything, I would never make it out of my driveway! :yesnod:
Old Mar 10, 2002 | 10:58 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
The spoiler is flexible, just drive right up on them, won't hurt a thing!
Old Mar 10, 2002 | 11:04 PM
C54TIM's Avatar
C54TIM
Here's a trick I learned! Lay towels down and put the ramps on the towels, let the towels stick out past the ramps. So when you drive up to the ramps the tires are on the towels. When you get to the ramps the ramps can't move because the car is on the towel and the ramp is on the towel. It's easier to do than try and explain it.
It works!
Old Mar 11, 2002 | 12:07 AM
mrkln's Avatar
mrkln
Default Re: Rhino Ramps? (C54TIM)
Yeah, just as everyone has said, let the ramps bend as they will pop back in place after they clear the ramps.
I am getting ready to lower my car so I will have to come up with something different then as I won't be able to run up on the ramps anymore. I plan on fabricating some pre-ramps or just some miniramps and then jacking the car manually and setting it back down on the ramps that I will slide under the tires once they are high enough. :cheers:
Old Mar 11, 2002 | 12:42 AM
Oldvetter's Avatar
Oldvetter
I just bought my second pair of Rhino Ramps. Read where one person jacked up car and slide second pair under other wheels (back wheels). $60 is cheap for a "mini lift". It gets car level for oil change and checking trans and differential.
Old Mar 11, 2002 | 04:59 AM
smithd7's Avatar
smithd7
Default Re: Rhino Ramps? (Oldvetter)
For the c-5 you really don't want the car level when changing the oil,due to pan configuration the rear of car should be higher than front.
:chevy :chevy
Old Mar 11, 2002 | 10:27 AM
shftn6's Avatar
shftn6
They bend slightly but won't hurt anything.
[Modified by shftn6, 8:29 AM 3/11/2002]
Old Mar 11, 2002 | 12:05 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Rhino Ramps? (shftn6)
"no touchy" DIY C5 ramps:
mikemercury.home.att.net/ramp.htm
[Modified by Mike Mercury, 11:07 AM 3/11/2002]
Old Mar 11, 2002 | 12:06 PM
gmblack3's Avatar
gmblack3
Here are some pics I took for putting a C5 on Rhino ramps:
http://www.picturetrail.com/gmblack3/647207
Old Mar 11, 2002 | 12:19 PM
VetteVert's Avatar
VetteVert
Default Re: Rhino Ramps? (gmblack3)
Well, I have more of a problem than that. I can't use the rhino ramps because the fascia (not the black rubber spoiler) hits the ramps before the tires get there. Even if I drive up on 2x10's first (which bend the rubber spoilers), the fascia hits before the wheels. Last time I changed my oil it took me 45 minutes to get the car in the air (working alone). However, my car seems to be in the minority here, and I'm getting ready to post (again) to see if anyone has any tips on lifting my car...
VV
Old Mar 11, 2002 | 12:22 PM
C54TIM's Avatar
C54TIM
gmblack3,
Nice ramps, so how do you keep them from sliding?
Or is the angle low enough that then tire catches it before it can?
Tim
[Modified by C54TIM, 8:23 AM 3/11/2002]
To Rhino Ramps?
Old Mar 11, 2002 | 12:25 PM
2ndVette's Avatar
2ndVette
Default Re: Rhino Ramps? (VetteVert)
if anyone wants a set of Rhino ramps FREE of charge, email me with your shipping account number (UPS, FedEx...) and $10.00 to defray my costs for finding a box and I will gladly ship those things to you just to have the relief of getting them out of my garage!
Old Mar 11, 2002 | 12:37 PM
Mark S.'s Avatar
Mark S.
Default Re: Rhino Ramps? (2ndVette)
build your own ramps using three 2"x12" boards, staggered properly (then glued and nailed together) you can easily stagger them so that you will never bend the small flexible spoilers, and you can also stagger them so that if you should drive off the top board, the next one below will be there so that you don't trap the ramp under your rocker panel. I made my own. You'll get about six inches of clearance. For the pic below drive up from right to left. Be sure that the top board has enough clearance to center your tire so that you can place chocks in front of and behind the front tire(s) when using your jack to lift the rear for a complete drain. Also, be sure to move the top board around 12 inches to the right (in case you overshoot your approach on the ramps)...pic did not display this.
e.g.
[Modified by Mark S., 10:57 AM 3/11/2002]
Old Mar 11, 2002 | 12:50 PM
2KVetteMan's Avatar
2KVetteMan
Default Re: Rhino Ramps? (Mark S.)
I use the Rhino ramps and my drive way is at an angle so saves me from jacking the rear up.
It was a little lesson on learning how to at first. Best way is take the ramps and jam them against the front wheels and slowly drive up on it. The ramps won't move anymore.
I just did it over the weekend for the second time, piece of cake.
