Shifter Bushing
Old Mar 9, 2010 | 06:29 PM
JVetthead's Avatar
JVetthead
Default Shifter Bushing
The plastic cup shaped bushing at the bottom of the shifter.
GM dont sell it by itself.
Anybody know of aftermarket bushing?
Thanks,
Joe
Old Mar 9, 2010 | 07:18 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I've never heard of an aftermarket one. You might try buying a stock shifter from someone who has installed an MGW shifter. They don't require the bushing.
Old Mar 9, 2010 | 10:53 PM
JVetthead's Avatar
JVetthead
I keep hearing about the MGW but have not seen one.. Have a link?
Have a B&M but it is getting sloppy.
Old Mar 9, 2010 | 11:47 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Try posting up a wanted ad in the for sale section. I had one but helped somebody else out in your situation.
Old May 25, 2010 | 10:06 AM
bumble-z's Avatar
bumble-z
I don't believe that is what the OP is wanting. He is wanting the plastic cup that covers the bottom of the shifter shaft.
Old May 25, 2010 | 11:22 AM
hotwheels57's Avatar
hotwheels57
If someone would manufacture and sell the plastic ring for the oem shifter boot and the plastic bushing for the bottom of the shifter, they'd have a long line of customers waiting...
Old May 25, 2010 | 01:14 PM
bumble-z's Avatar
bumble-z
You got that right.
Old May 25, 2010 | 06:15 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Whoops! My bad. Message Deleted.
Old May 27, 2010 | 11:04 PM
Garry_W_C5_1999's Avatar
Garry_W_C5_1999
I have one lying at home attached to original shifter (I installed an MGW). If it comes off easy enough without breaking it I can mail it to you for nothing. I will be home early next week and take a look, I'll send you a message and get your address.
Old May 28, 2010 | 12:26 PM
AllVette's Avatar
AllVette
The Gear Box (on E-bay) sells a bronze shifter bushing. Not sure if this is what you are looking for but you could call them and get the details.
T-56 Shifter Bushing
Old May 29, 2010 | 09:23 AM
JVetthead's Avatar
JVetthead
That looks like a bushing for the sliding rod. I dont think you could make the shifter cup bushing from anything but plastic as it snaps onto the bottom end of the shifter.
I did however tune my B&M shifter so it now works much better. I should have done a how-to for yall but was pressed for time.
The B&M has big orings between the part where the **** screws on and the shift lever itself for vibration isolation. Well after awhile these wear and shifting becomes very sloppy at best.. I was missing lots of shifts... not good on track.
So.. I removed orings and made a solid bushing out of PVC pipe and that took ALL the slop out of the shift arm itself.
For the sloppy plastic cup at the bottom I cut a piece of 1/8" rubber gaskit material about 1/2" or so in diameter and dropped it in the bottom of the cup and snapped it back on the shaft.. this removed most of the slop from that area. This is temporary at best as I am sure the cup will wear again but for now it works great!
No more missed shifts...
Knowing now the B&M has this isolation feature I would have avoided this shifter as vibration is not my concern...
Joe
And use grease on all moving parts..
Old May 29, 2010 | 09:40 AM
Mark C5's Avatar
Mark C5
Yep, you could do all that or just buy a MGW
Old May 29, 2010 | 09:59 AM
JVetthead's Avatar
JVetthead
there is one or more in every crowd....
To Shifter Bushing
