Skip shift solenoid socket size?
Old Mar 11, 2010 | 08:10 PM
enigma94's Avatar
enigma94
Default Skip shift solenoid socket size?
It appears my O-ring is leaking and I cant get a big enough wrench in there to take the solenoid out without removing the exhaust, can somebody tell me the what size it is so I can go purchase a deep socket for it?
TIA
Old Mar 11, 2010 | 10:18 PM
TEXHAWK0's Avatar
TEXHAWK0
Try using an open end wrench to get the size.
Old Mar 12, 2010 | 11:21 AM
enigma94's Avatar
enigma94
Well, theres a problem... I cant get a wrench that big in there without removing the exhaust as all of my wrenches close to that size are at least 14'' long. So again, can anybody tell me the size of the solenoid?
Old Mar 12, 2010 | 11:52 AM
Steve20's Avatar
Steve20
got a torch---? bend / cut the wrench to fit
Old Mar 12, 2010 | 05:04 PM
Its_Go_Time's Avatar
Its_Go_Time
TIA
It's 1 5/16 across the flats, but a deep 34mm axle nut socket will get er out.
Old Mar 12, 2010 | 06:21 PM
TEXHAWK0's Avatar
TEXHAWK0
Buy a 33mm socket and it will also work on the drive axle nuts that have been noted for getting loose.
Old Mar 12, 2010 | 06:34 PM
Its_Go_Time
33mm will fit the axle nut perfectly, but it won't fit the CAGS solenoid (1.300 vs 1.315).
Old Mar 13, 2010 | 03:54 PM
enigma94's Avatar
enigma94
Thank you! this is exactly what I needed to know.
To Skip shift solenoid socket size?
