Engine Builders ?
Old Mar 11, 2010 | 09:49 PM
postwhore's Avatar
postwhore
Default Engine Builders ?
What is the most HP and torque you can make with out blowers or nitrous using stock exhaust and stay smog legal ?
This is my goal.
Old Mar 11, 2010 | 09:54 PM
lucky131969's Avatar
lucky131969
This is my goal.
How much are you willing to spend?
Old Mar 11, 2010 | 10:03 PM
Roger Z06's Avatar
Roger Z06
California sucks [/thread]
Old Mar 11, 2010 | 10:04 PM
Roger Z06's Avatar
Roger Z06
Oh, bolt ons/ARP rod bolts/150 shot
Old Mar 11, 2010 | 11:57 PM
postwhore's Avatar
postwhore
Originally Posted by lucky131969
how much are you willing to spend?
$10k
Old Mar 11, 2010 | 11:58 PM
postwhore's Avatar
postwhore
not as much as Missouri
reading is fundamental , no nitrous
Old Mar 12, 2010 | 01:34 AM
Roger Z06's Avatar
Roger Z06
state initials are fundamental, Mississippi and we are dumb
No but seriously spray it.
Old Mar 12, 2010 | 04:23 PM
postwhore's Avatar
postwhore
ok , but there is no difference ,
No NOS
Old Mar 12, 2010 | 04:48 PM
hattitude's Avatar
hattitude
This is my goal.
Contact one of the sponsoring tuners/shops. Tell them your goals and they can steer you in the right direction. There are several who will do you right.
Ryne @ Cunningham Motorsports, Lake Elsinore, CA- the shop I use..
Charlie @ RPM Motors, Santa Clarita, CA- solid reputation
Andy @ A&A, Oxnard, CA - But be careful, he may talk you into supercharging
Good Luck......
Old Mar 12, 2010 | 05:22 PM
zeevette's Avatar
zeevette
10k doesn't go very far when you start buying parts to modify your present motor, and alot depends on what part of the build you're paying someone else to do. If you insist on remaining NA, there was a vendor here that's selling LS3 based longblocks (427!) for just under 10k. You also are going to need a clutch, and other drivetrain upgrades to handle the new power. Ooooooorrrrr, you can get a 5k or so A&A Vortech system, and put down even more power than the 427. But that'd be stupid, because it's no longer NA, right?
Old Mar 12, 2010 | 06:53 PM
BEARSZ's Avatar
BEARSZ
You're in NorCal so go talk to Rick @ Synergry, Nick @ Newtech and Mike at TPS. $10k doesn't go far in the land of CARB and NA LSx engines.
Good luck!
Old Mar 12, 2010 | 08:24 PM
postwhore's Avatar
postwhore
I was just tossing out a number. I'd spend more if really needed.
I figured tranny and drivetrain upgrades would run around $5k depending on what was a reasonable hp/torque figure.
I guess I was thinking money would not be eaten up as fast or as much because when you use the stock exhaust , there is only so much you can really do.
I was thinking the high buck stuff would be over kill.
Is the stock exhaust good enough for a 427 ?
Old Mar 13, 2010 | 12:52 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Its all depends on what we are starting with for an engine. AFR heads are legal in Cali and the stock exhaust flows decent enough. We offer anything from a 347 to a 506 so there are many many options.
Old Mar 13, 2010 | 01:25 PM
postwhore's Avatar
postwhore
basicaly I want to max it out but retain stock exhaust and "smoggability"
Old Mar 13, 2010 | 01:45 PM
99blancoss's Avatar
099blancoss
Former Vendor
Well we could take your engine and re-sleeve it and deliver a 457. Cam it accordingly and voila`. But it would be a little more than 10k. Small cam big heads big cubic inches = smooth street car
Old Mar 13, 2010 | 01:53 PM
postwhore's Avatar
postwhore
Old Mar 13, 2010 | 02:35 PM
99blancoss's Avatar
099blancoss
Former Vendor
Well in order to keep it CARB legal in Cali we would need to use GM OEM heads or AFR and since AFR does not have the big heads out yet LS7 heads would be fine.
This is the build right here:
http://www.ccperformanceparts.com/LS...ong_Block.html
We would substitute the TFS heads for LS7 and use a GM LS7 intake and port it. Cost would be about the same.
This is the top end of what you could do. We could deliver a 427 instead and save a good amount of money and bring it in at about 10k.
Use LS7 heads and again have your block re-sleeved but instead of going to a custom piston we keep the bore and stroke so we're able to use a shelf piston and a 4" stroke crank. This keeps costs down and being everything is OEM your legal with a sensible cam.
To Engine Builders ?
Old Mar 13, 2010 | 06:12 PM
Roger Z06's Avatar
Roger Z06
What will be great is when some guy who spent 2k on rod bolts and a nitrous kit drags the all motor 20k dollar build, to though.
Old Mar 13, 2010 | 06:40 PM
99blancoss's Avatar
099blancoss
Former Vendor
Well considering the OP doesn't want to spray it's a moot point but while you mention...LOL
n2o is often times a quicker way to that forged bottom end, it's more than just
the rod bolts thats lets go.
Plus the application factor comes into play. The only time you use n2o and reap the benefit of it is at WOT. More and more n2o is being outlawed as well as having the hassle of always making sure you have some in the tank, its up to pressure and you hope to god a noid doesn't stick.
It can be run very safely don't get me wrong but some people don't want to deal with the volatile nature of it. Some do I've got an LSX 434 sitting right here built for a 400 shot for a customer.
But as is said the OP would like n/a HP.
More cubic inches comes into play all the time and is not part time HP.
Dont get me wrong if your building a drag car a good n2o system is tough to beat.
Old Mar 14, 2010 | 01:44 AM
Roger Z06's Avatar
Roger Z06
I am just saying on a LS6/1 the only thing to let go on a 150-175 hit will be the rodbolts.
I am building a 408 stroker right now in my garage for my Z06 I will be putting it in the car saturday Forged crank, rods, pistons, and arp everything... I will be hitting it with a 150 at first and then up my solonoid size for a 250. As far as nitrous laws are concerened, "If racing were outlawed only outlaws would race" That is my take on that.
