LS6 Intake installed!!!!
Old Mar 11, 2002 | 05:59 PM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Default Re: LS6 Intake installed!!!! (C5Cemo)
I do not believe the newest version LS6 manifold offers more power over the older LS6 manifolds. The fix was for the "squeel" on some cars. Also, they changed manufacturers for the manifolds.
Nate
Old Mar 11, 2002 | 06:04 PM
C5Cemo's Avatar
C5Cemo
Default Re: LS6 Intake installed!!!! (Nate@xtreme)
I still have to wonder if they didn't do some performance tuning to the manifold since they we're investing in a new mold...might as well incorporate any new found data, etc.
Old Mar 11, 2002 | 06:15 PM
Patman36's Avatar
Patman36
Default Re: LS6 Intake installed!!!! (C5Noir)
:cool:
Patrick :smash:
Old Mar 11, 2002 | 07:03 PM
C5Noir's Avatar
C5Noir
It's a '02 manifold, Cemo.
Old Mar 11, 2002 | 08:03 PM
jmX's Avatar
jmX
Glad my site helped ya out man. Sounds like you had quite a gain!
Old Mar 11, 2002 | 08:37 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
HI there,
YOu are NOT getting blowby, as this is a normal operating characteristic of c5 class engines, as every one does it, plain and simple.
There is NOTHING that needs to be done.
Under WOT, or even slightly agressive driving, you will NOT be able to scavenge all oil vapor into the PCV system, and burn it.
Some will be pushed out the fresh air hose, into the intake, and thereby be deposited in the intake ports.
You are fine, and there is nothing that will cure this normal operating condition.
Just the facts here, and glad it all went well, c4c5 :smash:
Old Mar 11, 2002 | 08:49 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: LS6 Intake installed!!!! (c4c5specialist)
^^^ :cheers:
Old Mar 11, 2002 | 08:51 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Default Re: LS6 Intake installed!!!! (Mean Green 2000)
^^^ :cheers:
:yesnod: :yesnod: :yesnod: :seeya
Old Mar 11, 2002 | 09:02 PM
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
Default Re: LS6 Intake installed!!!! (70L46)
Whats up with SLP's LS6 manifold? $399 for eveything needed. Is this the old design?
Eric
Old Mar 12, 2002 | 12:57 AM
racetchr's Avatar
racetchr
If i changed the intake would the pcm relearn the change in flow if it has already been reprogrammed for cam? Or would I have to have programming again?
Old Mar 12, 2002 | 02:23 AM
C5Noir's Avatar
C5Noir
c4c5, thanks for the clarification regarding the oil covered intake port. I also appreciate your write up with tips/tricks on the other C5 Forum. They were invaluable. My hat is off to you, :cheers:
Old Mar 13, 2002 | 10:51 AM
TLewis4095's Avatar
TLewis4095
Current part# is 88894339 :cheers:
Old Mar 13, 2002 | 01:29 PM
  #33
C6~Missle's Avatar
C6~Missle
C5Noir.. sounds nice. Does the 02 LS6 intake fit on the LS1's? I have a 99 FRC that I am always willing to improve..
mike
Old Mar 13, 2002 | 01:30 PM
  #34
C5Noir's Avatar
C5Noir
Default Re: LS6 Intake installed!!!! (C5~Missle)
mike
Oh yes, will fit like a charm!
Old Mar 13, 2002 | 06:17 PM
  #35
Red 5's Avatar
Red 5
Default Re: LS6 Intake installed!!!! (racetchr)
I did this mod on my 98 last fall. It definitely made a difference! The car idles better, is definitely stronger. I also don't get that "marbles" sound on first gear lugging(6 spd).
My only 3 recommendations for do it yourselfers. 1) Have owners manual 2) get new manifold bolts 3) a good quality torque wrench. If you skimp on the last 2 you can e-mail me on How To Remove a Broke Bolt From Your C5 Head! That was my extra experience! Enjoy!!!! :cheers:
