Best Brake Pads?
Old Mar 11, 2002 | 03:58 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Best Brake Pads?
What type should I get, the brakes are just starting to make noises. Should I just pickup up some ZR perfromance friction from a local parts store, or hold off a little and order something else?
Old Mar 11, 2002 | 02:13 PM
MelloYellow's Avatar
MelloYellow
Default Re: Best Brake Pads? (TexCorvette)
Do you want best performance or low dust and less performance?
Good performing pads will dust a good bit.
I prefer the EBC Green Kevlar's over the Hawk Streets.
Also, depends if you mean street or heavy track.
[Modified by MelloYellow, 1:13 PM 3/11/2002]
Old Mar 11, 2002 | 03:42 PM
TexCorvette
Default Re: Best Brake Pads? (MelloYellow)
I would say performance.
Old Mar 11, 2002 | 04:32 PM
MelloYellow
There is Street Performance then Track Performance.
Track Pads don't bite as well on emergency stops but they don't fade or succuum (sp?) to heat issues as Street Pads would. Streets are also harder on rotors.
Max stopping power on occasion, ie: Street? Street Pads with higher grip than Track.
Old Mar 11, 2002 | 04:38 PM
CRUZMISL's Avatar
CRUZMISL
I had Hawk pads and when wringing your car out they are great but make more dust than I cared for. Initial bite also suffers somewhat but if you are really moving they work great. I hear the 02 Z06 pads are very good so that's another option.
Old Mar 11, 2002 | 09:28 PM
aces's Avatar
aces
Default Re: Best Brake Pads? (CRUZMISL)
I had EBC green's and ended up with alotta hot spots. Toasted the rotors and they were properly bedded.
Old Mar 11, 2002 | 10:38 PM
MelloYellow
Default Re: Best Brake Pads? (aces)
I am seeing some hotspots, but no problems. I have resurfaced these twice. Will replace them next time around. The pads definitely GRIP!
Old Mar 11, 2002 | 11:08 PM
TexCorvette
Well I know there is street and track performance, you went back and edited your orginal post/question, thus my original short responce. I would say street use, as it will only see a few monthly drag strip runs, and maybe a few track days per year.
I think I will see if the dealer has z06 pads in stock, or just get the best bads from a place like AutoZone/Pepboys/checkers.
[Modified by TexCorvette, 1:25 AM 3/12/2002]
Old Mar 12, 2002 | 02:23 AM
TexCorvette
Okay, I went ahead and picked up Raybestos QS with Ceramic Enhanced formula. They where $80 for the front pads and $57 for the rears. They also came with lifetime free replacement, let me know what you guys think?
I hear Raybestos are supposed be good, and these are supposed to be a bit better than OEM but on par with them at the very least?
Old Mar 12, 2002 | 08:20 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Raybesto's are good for street driving but from 140 in a hurry they will fade.
Old Mar 12, 2002 | 09:44 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Best Brake Pads? (John Shiels)
Raybestos are quiet and create no dust, but as far as stopping power, THEY SUCK!! I have had them on my car for about a year now and can't wait to go with a pad that actually stops the car. I will probably keep them for street driving until they wear out but for track sessions this summer I just bought a set of PFC 01s for the front and PFC 99s for the rear.
Unfortunately it is impossible to get awesome braking power, low dust, low noise and long rotor life out of one brake pad.
Old Mar 12, 2002 | 04:04 PM
TexCorvette
Default Re: Best Brake Pads? (MattG)
Do THEY SUCK for street use, or just track? Do they compare to stock or not as good?
Old Mar 12, 2002 | 05:04 PM
MattG's Avatar
MattG
They are SLIGHTLY worse than stock for street use. Unless you drive the car real hard and use the brakes a lot, you will never notice the difference between them and stock.
Old Mar 12, 2002 | 05:12 PM
TexCorvette
calling the dealer right now to see if I can get 02 Z06 pads, these are better than stock C5, correct?
Old Mar 12, 2002 | 05:31 PM
TexCorvette
Dealer says the part number for the 02 z06 pads are the same as a standard C5!?? Dealer also wants like $170 for the front pads!!?? :eek:
[Modified by TexCorvette, 4:32 PM 3/12/2002]
Old Mar 12, 2002 | 05:59 PM
qs01coupe's Avatar
qs01coupe
Contact Ken Fichtner for a great price on OEM break pads. You can also try gmpartsdirect.com.
Old Mar 12, 2002 | 06:37 PM
360Lemans's Avatar
360Lemans
I had the same problem with my 98 coupe. The EBC will fade from high speed stops. I would not recommend EBC green's for performance. :flag
To Best Brake Pads?
