Broke the radiator drain
Old Mar 13, 2010 | 11:15 PM
Autobot's Avatar
Autobot
Default Broke my pet ****
So I am pretty frustrated at this point...I went to flush the coolant on my rig and was just about finished. I was installing the petcock, but as I usually do I started late, and it had gotten dark so I couldn't see all that well, I go to tighten the petcock and I couldn't see so I gave it a bit more, and well I broke it. It just spins now, since I was ticked I just dropped the car and came in now, will finish tomorrow I guess, will get up early and get the parts.
Question now is, how do I remove my broken drain, I am looking for some guidance from my brothers of the broken **** club (BCC). Ya I said that, and I don't think viagra is going to help here.
Thanks in advance for your help.
Old Mar 14, 2010 | 01:03 AM
Autobot's Avatar
Autobot
So I think I have probably broken the pin in which case it should probably just pull out...will try tomorrow. Looks like no one wanted to touch my broken pet **** problem.
Old Mar 14, 2010 | 01:42 AM
feb2910's Avatar
feb2910
Cruising
http://www.rockauto.com/catalog/moreinfo.php?pk=12513
above is what the replacement drain **** looks like. original didn't have a thumb hold piece. it had a 1/4 sq drive recess. pin is steel and usually corrodes from acidic build up in unchanged coolant. you may have rounded off or broke the pin or cracked the plastic that hardens with heat and time. may need a pair of needle nose to get the old out. new replacement is cheap maybe 5 bucks most.
Old Mar 14, 2010 | 10:08 AM
Fast Cop's Avatar
Fast Cop
Been their, done that. Not to worry its a $5.00 fix with NAPA know how.
Old and New
Old Mar 14, 2010 | 10:36 AM
ILM-Express's Avatar
ILM-Express
MFIC
good info
Old Mar 14, 2010 | 02:01 PM
Oldvetter's Avatar
Oldvetter
I've done it too ! NAPA part is better as you don't need a 1/4 inch socket drive to turn it.
I always caution people when removing it, just a 90 degree turn then pull it out gently.
Old Mar 14, 2010 | 02:10 PM
Autobot's Avatar
Autobot
So being in Canada I am getting screwed, Napa doesn't have it and another local parts store that I hate wants $9 for it, the same one Rock auto sells for $3. I am going to wait until Monday to see how much the stealership wants for it.
Old Mar 14, 2010 | 05:56 PM
Autobot's Avatar
Autobot
Bit the bullet as it wasn't worth the extra drive to go somewhere else but it cost me $8. Anyways, if anyone does this in the future, when the pin is broken it just pops right out, I pried it a bit with a screw driver and it came out easy.
Old Mar 14, 2010 | 06:49 PM
TEXHAWK0's Avatar
TEXHAWK0
You really should not try to open the drain **** by feel.
You need to get where you can see the slot in the radiator housing and line the pin up with the slot before you pull it out.
I think the pin is supposed to help drive the drain open, but try to work it out by hand so I don't break anything.
To Broke the radiator drain
