Question for Vararam owners
Old Mar 15, 2010 | 06:54 AM
gdaddee's Avatar
gdaddee
Default Question for Vararam owners
While holding the throttle constant at about 2000 rpm for instance, the car will surge slightly. It is not noticed while accellerating, only while holding steady or decellerating. It's like the accellerator is overly sensitive. It was not that way before the Vararam install. All connections are tight. I installed it about 2 months ago. Anybody had similar experience?
Old Mar 15, 2010 | 07:23 AM
toplessta's Avatar
toplessta
I had to get a tune to get rid of the surge
Old Mar 15, 2010 | 11:04 AM
AFRob's Avatar
AFRob
Same here.
Surging at low RPM.
Also had to get a tune.
Old Mar 15, 2010 | 11:16 AM
gdaddee's Avatar
gdaddee
Starting to see a pattern here. Thanks for the replies.
Old Mar 15, 2010 | 11:52 AM
dbstephens's Avatar
dbstephens
I had the same problem with my 2004 Z06 after changing from the original style Vararam to the new B2 version. I was also getting the check engine light and bank one lean codes on the DTC. My engine had previosly been dyno tuned with the old intake.
I added a laminar flow straigtener: http://www.halltechsystems.com/Hallt...r_p/hc.125.htm which strangely enough, got rid of the surging and turned off the associated lean bank 1 codes that I kept getting.
I have seen no degridation in performance after installing the honeycomb screen.
Old Mar 16, 2010 | 07:46 AM
Logg's Avatar
Logg
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18
My 2000 frc also does what you describe and has that intake. I've only had the car for a few days and have not put 2 and 2 together untill I saw this thread. Have had many C5's but none that have done this. This is also the only one I've had with the Veraram
Old Mar 16, 2010 | 11:26 AM
gdaddee's Avatar
gdaddee
Yeah, in all the threads I read before deciding on the Vararam, no one said anything about needing a tune afterward!
Old Mar 16, 2010 | 11:30 AM
91Vette's Avatar
91Vette
Good to know. I have a Vararam, but was waiting till spring to put it on. Might wait until I plan some other mods and then get a tune to make the car run best.
Old Mar 17, 2010 | 06:45 PM
dbstephens's Avatar
dbstephens
I installed the Vararam B2 system on my wife's 2001 6-speed Convertible, at the same time as my Z06 installation. It has the factory honeycomb MAF sensor screen. It has not been tuned, but has a Corsa exhaust system.
The car runs great and does not exhibit the surging that my tuned Z06 did after the install.
Stock Z06's do not have a laminar airflow straightener on the MAF sensor like the other models do.
I now am a fan for not "de-screening" your MAF sensor.
Old Mar 17, 2010 | 07:30 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Mine did that after install for about a month; then never happened again. In any case, I've since installed long tubes and had a new tune done for them plus the VR, so in a few weeks when the snow is gone I'll see how she runs!
Old Mar 17, 2010 | 09:54 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Just to let you know... 2001 Zo6s got the screened maf. GM removed the screen in '02.
Does anyone know what the tuners did to help the surge? Add timing? Add fuel? Bueller??
Old Mar 17, 2010 | 11:55 PM
SJSZ06's Avatar
SJSZ06
I put a Vararam (b2) on my '02 Z06 along with their Power Duct.
The Power Duct caused codes, so I took it back out until
I could get a dyno tune. It ran fine with just the Vararam.
Is anyone having problems using the Power Duct?
Old Mar 18, 2010 | 10:12 AM
AntonioZ06's Avatar
AntonioZ06
Did you unplug the battery when you put in the vararam? If not, you should unhook the battery for about an hour or so. Then hook it up again and go driving around for a bit. The ecu should start to relearn the intake. Should help a bit.
Old Mar 18, 2010 | 12:02 PM
rebelheart's Avatar
rebelheart
I have both the B2 and their power duct and have had zero issues,unless you consider 3/10's quicker ET's an issue.
Old Mar 18, 2010 | 08:11 PM
dbaker's Avatar
dbaker
Never had the surge,but did have the codes after installing the VR Power Duct...seems to be too much turbulent air.
The Halltech screen worked for me...$40 and install in -5min.
\db2
Carolina
Old Mar 18, 2010 | 10:36 PM
BanditDude's Avatar
BanditDude
I would look for an air leak. I had a loose connection on the coupler that caused me some problems.
Old Mar 18, 2010 | 10:52 PM
Michael99Vette's Avatar
Michael99Vette
Default Vararam
I installed the Vararam and Power Duct on my 99. It didn't have the surge problem. It seemed to run fine. I took it in for a dyno tune and I'm glad I did. Under normal driving it did run fine but my Tech started to pull the first run and had to shut it down immediately. It was running way too lean. He said under normal driving the computer was able to make the adjustments. Under hard driving I could have burnt a hole in my pistons. Fortunately I was driving it cool. You need to watch out for extra lean conditions!!
To Question for Vararam owners
Old Mar 19, 2010 | 07:40 AM
rebelheart's Avatar
rebelheart
I think your tuner was yanking your chain a bit.If it was running as lean as he said,it would have had all sorts of driveability issues!
Old Mar 19, 2010 | 12:21 PM
907VET's Avatar
907VET
I just installed the b2 w/bridge on my 2000 and the only thing I had was the check engine light came on, once I shut it off and restarted it never came on again. I also had to keep the MAF in front of the bridge, in 2000 they used 2 different motor mounts from what I've been told and I got the ones that sit the motor lower so I had a hell of time just getting the coupler and bridge to fit so there was no way of getting the MAF in front of the TB.
Old Mar 19, 2010 | 08:32 PM
Nick1's Avatar
Nick1
Guess I'm lucky! After two years and good performance, no codes or surging!
