E brake light stuck on
Old Mar 15, 2010 | 09:28 PM
SlowFRC's Avatar
SlowFRC
Default E brake light stuck on
Car is a 99 FRC, the e brake light in the gauge cluster has been stuck on for 6+ months, it won't go out. This obviously isn't a huge problem but it's a mild annoyance. Anyone else had this problem? Any ideas on how to fix it?
Old Mar 15, 2010 | 10:15 PM
Carcass's Avatar
Carcass
There's a small microswitch under the boot that the e-brake mechanism either depresses when the lever is up or when it's released(can't remember which,been awhile since I was in there),it can get either dirty or rusty,or just plain fail.
Peel the boot up a bit from the passenger side and you'll see it.
That's what I'd check first.
Old Mar 15, 2010 | 10:17 PM
lucky131969's Avatar
lucky131969
I believe a low brake fluid level will illuminate the brake warning as well.
Old Mar 15, 2010 | 10:30 PM
byronhunter's Avatar
byronhunter
Originally Posted by lucky131969
I believe a low brake fluid level will illuminate the brake waring as well.
Zactly Right!
Old Mar 16, 2010 | 03:58 PM
SlowFRC's Avatar
SlowFRC
Do you have a picture or diagram of what I should see when the boot is off or is the switch really obvious?
Brake fluid is full guys, thanks for the suggestion though.
Old Mar 16, 2010 | 04:06 PM
lucky131969
Just because the brake fluid is full, does not mean there is not a problem with the circuit. Unplug the fluid level switch to be sure.
Old Mar 16, 2010 | 09:32 PM
Carcass's Avatar
Carcass
Sit in the drivers seat,lean over and peel the velcro open where the e-brake boot goes behind the carpet.
The switch is apx halfway up the side of the tunnel,in a line with the front of the console armrest/cushion. Little blue switch with a flat arm about 1/2 inch long sticking out of it on the bottom side,and a wire plugged into the tunnel side of it.
IF the e-brake handle mechanism isn't depressing it when it's released,the brake light on the dash will stay on.
Old Mar 17, 2010 | 09:25 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
I'm going to check mine out
Old Mar 17, 2010 | 10:41 AM
SlowFRC's Avatar
SlowFRC
Thanks guys, for some reason the brake lever wasn't moving the switch when I used it, just left it in the off position so I don't have to worry about it anymore.
To E brake light stuck on
