Key fobs
Old Mar 16, 2010 | 12:49 AM
Ederasu's Avatar
Ederasu
Default Key fobs
Hello everyone Im sure this is a stupid question but i was wondering if 2002 z06 key fobs will work on a 2001 z06. thanks everyone.
Old Mar 16, 2010 | 08:15 AM
Gideon's_Test's Avatar
Gideon's_Test
Sure, they'll work, you'll just have to reprogram it via the DIC...
Old Mar 16, 2010 | 08:57 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Programming Transmitters
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Old Mar 16, 2010 | 09:18 AM
65GGvert's Avatar
65GGvert
All 2001-2004 C5 fobs are iinterchangeable. I just saw a set of two on ebay for $28 with free shipping and others for $15 each.
Old Mar 17, 2010 | 10:37 AM
tonyb47's Avatar
tonyb47
i have a 2000 conv with only one key fob, i purchased another one off ebay also from a 2000, and matched up the part number and the abt number on the key, but I can't program it. the original reprograms,but when I try to do the second it won't program. I had the new fob tested at a the dealer and it is in working order. Any Ideas
Old Mar 17, 2010 | 05:25 PM
65GGvert's Avatar
65GGvert
Tony, you should start your own thread with this question. It's against the rules to hijack another thread, plus it doesn't focus the answers to your problem. When you do, I can give you some ideas, or if you like pm me.
Old Mar 17, 2010 | 05:42 PM
Oldvetter's Avatar
Oldvetter
There were #1 and #2 key fobs, maybe you got two of the same # and they conflict. This is just a guess.
Old Mar 17, 2010 | 05:48 PM
65GGvert's Avatar
65GGvert
Either will program as either, depending on the order you program. That won't be his issue.
Old Mar 18, 2010 | 06:00 PM
65GGvert's Avatar
65GGvert
PM answered
To Key fobs
