Clutch
Old Mar 17, 2010 | 10:16 PM
mfriley's Avatar
mfriley
Default Clutch
Ok so I was doing a burnout the other day and the only thing that burned was the clutch. Major bad smell... It does not slip on hard 1-2 or 3-4 shifts infact it does not seem to slip at all except on initial take off. I admit that I tend to feather it a bit on take off but this slippage is new. Regardless i'm getting the burnt clutch smell pretty frequently now. So I was looking for a DIY thread on clutch replacement. I know it's a big job but is it a shop job? I've done several auto replacements on other cars but never a clutch. What am I looking at here and if I go with a shop how much am I looking at.
Mike
Old Mar 17, 2010 | 10:26 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I would guess about $600 just a guess. Im about to do mine. I found a DIY that DOPE did. I also saw one from someone and they didnt pull everything out to do the swap. I have tried to find it but I cant.
Old Mar 17, 2010 | 10:39 PM
tommie's Avatar
tommie
my brother did his in his garage using jackstands......
should be able to find several write ups...
Old Mar 18, 2010 | 09:13 AM
waddisme's Avatar
waddisme
Local shop around here charges like $450 to install. When you see how many things you can mess up, and how hard it is, it is really worth the $450. If you can get it on a lift it might be a little easier, but to me, still not worth the $450 saved. If you do it yourself, do a search for the dope install. Good luck either way.
Old Mar 18, 2010 | 09:30 AM
dougbfresh's Avatar
dougbfresh
Agreed-this job is MUCHO easier on a lift with REAL trans jacks and room to work.
Old Mar 18, 2010 | 10:18 PM
argonaut's Avatar
argonaut
If you have access to a lift and a great set of tools its a straight forward DIY (done two of them). Personally I wouldn't want to do it on jack stands.
Old Mar 18, 2010 | 10:36 PM
tom01ss's Avatar
0tom01ss
Former Vendor
very easy to do on ur back you will need 2 ppl when it comes time to drop rear trans and torque tube
Old Mar 18, 2010 | 10:49 PM
BanditDude's Avatar
BanditDude
Here are the DIY instructions you were looking for.
http://www.cajundude.com/c5techhome.htm
To Clutch
