CLB question
Old Mar 19, 2010 | 10:43 PM
Rich-'s Avatar
Rich-
Default CLB question
bear with me, i am still a new guy
98 auto..
i guess my car had the work done at the dealer, and there shouldnt be any issues with it leaving me stranded, but i still get the code on the dash, (pull key weight 10 sec.)
the kit from corvettes of houston for $50 is that what will make it go away?
what else do i need to know? thanks guys
Old Mar 20, 2010 | 02:13 AM
Carcass's Avatar
Carcass
Sometimes,if the contacts in the ignition switch,or the resistor pellet on the key are dirty,you'll get that message from the DIC -it MAY not be a column lock related thing
Try cleaning the pellet contacts(little black thing on the key) and the contacts in the switch with a q-tip and rubbing alcohol and see if that helps-it cured the same problem on my 98 MN6
Haven't heard real good things about the dealer "fix",so it may be worth the $50 clb just to be sure.
There is no "good" place to be stranded in your Vette.
Old Mar 20, 2010 | 07:11 AM
lucky131969's Avatar
lucky131969
98 auto..
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Mar 20, 2010 | 08:17 AM
Rich-'s Avatar
Rich-
Originally Posted by 8VETTE7
It may not help. Some of the early cars, 1997 through 2000, get the error message even with a CLB installed. I would find a tuner with either EFI Live or HP Tuners tuning software and have the fuel shutoff set to a large number like 200mph and ignore the error message. The message is just annoying. The fuel shutoff strands you.
i guess this was already done, so there should be no issues with being stranded, i just have the annoying message
To CLB question
