Security light comes on in tunnels
Mar 22, 2010 | 08:38 PM
Cruising
So here's a strange one for you..
My C5 has the SECURITY light come on whenever I drive into tunnels, every time, without fail. It also throws a B2723 code in the BCM.
Any ideas on this one?
Mar 22, 2010 | 09:57 PM
Afraid of the dark?
Couldn't resist....... TTT
Mar 22, 2010 | 09:59 PM
Cruising
Quote:
Originally Posted by
ALLEGRO
Afraid of the dark?
Well it does have stock headlights still...
In all seriousness, I wonder if they have any radio widgets that would interfere with passlock? Does anyone know if it uses anything other than the dinky little resister in the key?
Mar 22, 2010 | 10:35 PM
B2723 is for PASS-Key detection circuit. Maybe a bad ignition switch??
Mar 22, 2010 | 11:12 PM
How many keys on your fob?? I was told that you shouldn't have to much weight on the ignition key . Just a shot in the dark.....
Mar 22, 2010 | 11:13 PM
Stay out of tunnels.
Mar 23, 2010 | 01:26 AM
Its trying to tell you its wants to be floored to make some noise!
Mar 23, 2010 | 01:55 PM
Cruising
Bill Vett
That could be something. The steel climber's clip I use as a key-chain, and the drainage grating at the tunnel entrances jostling the whole vehicle.
Odd that the rest of the bumps on Oahu's craptastic roads wouldnt cause it though.
Mar 23, 2010 | 08:18 PM
Wounded Warrior Escort '11
Just a dumb thought, try covering the twilight sensor on the top of the dash pad and see if it happens again. If not, manually turn on/off your headlamp switch and check again for any correlation.
