Torque Convertor Lock-up....when does it occur?
At what stock RPM does this occur?
With higher than stock TC's does it occur at proportional rpms to stock?
Is lockup rpm programable?
:confused:
:confused:
I can't tell you what rpm, but it is programmable so someone with LS1Edit could tell you as they've seen the numbers.
I've been trying to "feel lockup" but don't know what I'm feeling for.
Should the TC lock-up at or just above the stall speed?
or is it a personal thing,or performnace thing.
I' ve been considering swapping for higher stall TC but I'm confused about the lock-up. I'm also on overload on stall speeds and STRs. But with my 3.15 I think I want 3000/1.86 maybe a little lower. :rolleyes:
The most annoying TC lockup design I have seen from the factory is in my Expedition. :cuss Letting off the throttle at cruise speeds and reapplying results in an RPM surge that feels exactly like a slipping tranny (because it is, the converter is unlocking and then locking.)
[/QUOTE]
Soooo, that's what it feels like, *ell, i feel it now.
And.. so it locks up above stall speed right :confused:
I've got an A4 with the 3.15. I'll be cruzin' at about 40 or 45 (what is stall speed?) and go to "goose" it and the d*mn thing seems to up-shift. All performance is now lost because I have to push the pedal harder to get it to down shift again.
Anyway, will the Powerloader help with this?
%TPS 0 6 12 18 25 31 37 43 50 56 62 68 75 81 87 93 100
3rd apply 28 28 29 35 43 50 56 87 87 87 87 87 87 255 255 255 255
(in mph)
in 4th it applies at 42 mph until above 81% of the TPS.
So basically it looks like at WOT you are not locked, only locked until about 81% of WOT.
Using LS1Edit or any programmer such as Steve Cole you can program the t/c lockup. :cheers:
oh yeah just to be clear, that 0, 6, 12, etc table, the corresponding MPH are directly below.
[Modified by intel55, 2:01 PM 3/12/2002]
Well, that particular example was from my Expy and is a result of the release occuring too quickly (i.e. very little change in road speed.) My A4 didn't behave that way even before I tweaked the programming. The lockup is a function of both vehicle speed and throttle position, not just a simple RPM thing. If you're seeing an annoying release/reapply scenario, the release may being triggered by the misfire detection logic. You still have the stock converter and programming (the HPP3 doesn't do anything wrt the TCC), right? Maybe you could talk a little bit more about exaclty what you're experiencing...
yes i still have stock TC
No i've reprogrammed 1-2 +2mph, 2-3 +4mph, 3-4 stock...75% firmness
I have no misfires, in fact everything is schweet xcept for the shifts
I'm not happy with the downshift when I mash it still feels slushy too me. I guess the slush I feel is what needs to be taken out by transgo shift kit.
[Quote So basically it looks like at WOT you are not locked, only locked until about 81% of WOT. ]
Is this to protect the drive line from the higher Horsepower?
:confused:
The spread in mph between lockup and unlock in a given gear is what results in the fundamental characteristics you will feel SOTP. Now add in to that, shift firmness which clouds what may be happening (lockup and unlock feels like a shift point). Tuning the A4 in this area, the mph spread and resultant curves is what we watch number 1.
The funny thing is, tuning the engine for peak performance is relatively easy compared to tuning the A4 to suit a particular individuals SOTP feel.
Hope this helps.
From what all's been said lock-up is a compromise..... trial and error adjustment... with precise adjustment available for certain driving conditions...x-cross, drags or street. something not easily accomplished.
Just like picking a cam. :cry
your data seems to say that there is no lockup in first or second gear; which is what I have noticed on mine.
How to tell if it is NOT locked:
a) if you are cruising at a constant speed, let off the gas. if the RPM guage swings down a few hundred RPM, it's NOT locked
b) if you are coasting (on highway, etc) and give the car a quick bit of gas, you will see the RPM guage swing up a few hundred RPM and then swing back down
The TC >>IS<< locked when the following happens:
a) if you are cruising at a constant speed, (not accelerating or anything) let off the gas. if the RPM guage stays more or less in the same area/range, it is locked
b) if you are coasting (on highway, etc) and give the car a quick bit of gas, you will see the RPM guage stay in roughtly the same area/RPM.. maybe it will jump up a bit, but not much.
Oddly enough, I notice the TC activity more so on my Jeep Grand Cherokee Ltd than the Vette. That must be because of the gearing for towing/etc.
A good visual way to see when TC lockup occurs is to accelerate quickly to highway speeds from a stop and then level out to a nice cruising speed. If you watch your tach, you will notice that after a short while, you will feel some activity in the driveline and the RPMs will drop 100+ RPMs with no change in vehicle speed. That was the lockup.
[Modified by ToplessTexan, 12:37 PM 3/13/2002]
