ID a differential
Old Mar 25, 2010 | 04:07 AM
HD_2_C5's Avatar
HD_2_C5
Default ID a differential
Is there a way to ID a differential? I ordered a 3.42 differential online but they sent me a 3.15 by mistake. Then they sent me a second one but this one doesn't have the tin ID tag on it indicating the gears that the first one had. Is there a way to confirm prior to install? I'm fairly confident it's correct but would feel a little better if I could confirm it. There is a serial number or something stamped in the housing and it is a Getrag housing.
Old Mar 25, 2010 | 05:19 AM
travelingypsye's Avatar
travelingypsye
Count the teeth on the ring & pinion.
On a 3.42 there are 41 teeth on the ring (large gear) & 12 on the pinion.
Old Mar 25, 2010 | 09:04 AM
lilicedout24's Avatar
lilicedout24
hey can you use a c6 diff in a c5?
Old Mar 25, 2010 | 09:49 AM
bumble-z's Avatar
bumble-z
I believe you'd have to go w/ the C/6 cradle too.
Old Mar 25, 2010 | 11:47 AM
WKMCD's Avatar
WKMCD
Only if it's a C6 Z06 rear - IIRC
To ID a differential
