c5 rear diff fluid? - Tranny?
Old Mar 25, 2010 | 03:53 PM
Vett-a-matic's Avatar
Vett-a-matic
Default c5 rear diff fluid? - Tranny?
While at the autopart store, i decided to get rear end fluid (00 C5 6speed), and the guy told me it takes GL5, and i thought a synthetic would be good.
He recommended the Redline 75-90 synthetic fluid. after reading it in confusion about limited slips, i may need to add some sort of anti slip additive.
i drained it and put it in anyway, as what came out was dirty, and the new fluid resembled new/clean GL5, it was actually thicker than i thought it would be being synthetic. Anyway, it said something about rear end chatter and what not.
My question, is will this Redline be OK in there? Or has anyone used this fluid? anti slip additive?Iam assuming that it may have the potential to leak as do engines when seals are used to petroleum based oils and are then switched to synthetics.
Can i change the Tranny fluid as well? Fluid recomendations?
I dont even want to think about any fluid lasting 100,000 miles. NOT IN MY VEHICLES, thank you
Thanks guys in advance
Old Mar 25, 2010 | 04:03 PM
Bash's Avatar
Bash
Trans - Mobil 1 Synthetic ATF.
Rear end - Mobil 1 Synthetic 75W-90 Gear Oil with GM Limited Slip Additive.
Old Mar 25, 2010 | 04:22 PM
VetteHunting's Avatar
VetteHunting
Trans - Amsoil ATF
http://www.amsoil.com/catalog.aspx?GroupID=208
Diff - Amsoil Severe Gear 75/90 w/ Amsoil Slip-Lock added as neccessary.
http://www.amsoil.com/catalog.aspx?GroupID=95
http://www.amsoil.com/catalog.aspx?GroupID=88
Old Mar 25, 2010 | 04:58 PM
Sinister-one's Avatar
Sinister-one
Originally Posted by VetteHunting
Trans - Amsoil ATF
I could not agree more !!
That's exactly what I buy from Amsoil for my FRC.
Old Mar 25, 2010 | 05:50 PM
Vett-a-matic
OK i just called Redline, like i should of in the first place, but being at work i was just lazy.
the 75-90 GL5 will be fine and has limited slip additives
The 75-90GL5 NS however does not have additives and needs 5% limited slip additives and is not recommended in the vette unless the additive is mixed in.
Thanks for the other recommendations,
Old Mar 25, 2010 | 05:53 PM
Bash's Avatar
Bash
Im Running all mobile 1 stuff, due to the timing of me fixing my car. When I do swap the fluids coming up, I am going with redline! Looks promising!
Old Mar 25, 2010 | 06:38 PM
Vett-a-matic
Originally Posted by Bash
Im Running all mobile 1 stuff, due the timing of me fixing my car. When I do swap the fluids coming up, I am going with redline! Looks promising!
Yeah I have used their products with motorcycles. And have had good results. They are also local for me here in the bay area (CA) never used Amsoil and I don't use the mobile one products. Any good solid name brand should be fine az long as the fluid is changed regularly.
Old Mar 26, 2010 | 10:42 AM
lakelaw's Avatar
lakelaw
Trans - Amsoil ATF
Do you really need additional anti slip with the Amsoil 75-90 severe gear fluid? Doesn't it has the anti slip in it already? Total of GM anti slip for empty differential is 4 oz.
Old Mar 26, 2010 | 10:51 AM
lucky131969's Avatar
lucky131969
Dexron III.
Old Mar 26, 2010 | 11:25 AM
Last C5's Avatar
Last C5
Exactly right. I've been using Redline 75/90 in both my track car and my vert for years. It's the way to go. It's also the recommended fluid of several performance differential rebuild companies.
I use Redline DT4 in my verts transmission and Redline's High Temp Auto fluid in my track car.
Old Mar 26, 2010 | 02:02 PM
SaberD's Avatar
SaberD
the c6 diff fluid is the best you can get: gm part # 88862624
transmission:
97-00 amsoil ATF or ATD
01-04 mobil 1 synthetic atf
Old Mar 26, 2010 | 06:29 PM
hatewhatownsyou's Avatar
hatewhatownsyou
no you dont, it does come with the stuff in it already
Old Mar 29, 2010 | 05:20 PM
Vett-a-matic
Default noise
OK, so i drove the car around this weekend, and noticed small noises coming from the rear end when making turns with wheel locked. Minor noises but annoying. Makes me wanna flush the **** out. Of course i threw the receipt and old bottles away. Im pretty sure it was the 75-90 and not the 75-90NS, which has the limited slip additive..
Old Mar 29, 2010 | 06:24 PM
lucky131969
Yet Amsoil still issues this disclaimer:
AMSOIL SEVERE GEAR® is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifier additive.
Old Mar 31, 2010 | 08:22 PM
lrcipo's Avatar
lrcipo
3rd Gear
Default Rear Gear Oil Change Out - C6
I just got an 2006 C6 with 18,000 miles on it. Only problem I noticed with the car after I bought it was that the rear made a grinding noise, mostly when cold. I did not notice this on the test drive. I brought to chevy dealer who said right away that a service bulletin had been issued about the posi rear gear oil - the original oil allows the grinding noise and has to be replaced with a synthetic type. Unfortunately I don't know what they put in it, but it solved the problem, and I assume its a "standard GM" product. Service manager told me to go to empty parking lot and do a dozen quick figure eights to swoosh it all around. I enjoyed that almost as much as not having to face the wifey with a big repair bill.
Old Nov 12, 2019 | 12:33 PM
Robert Sawko's Avatar
Robert Sawko
6th Gear
Changed the differential fluid in my 2004 C5 two weeks ago. Used AC Delco 75W - 90W fluid with Limited Sip Axle Lubricant (32oz) and also added 4 oz of AC Delco Limited Slip Axle Lubricant. Made a long trip to Cambria, CA and back and the grunting/grinding noise was gone from the car. You need about 57 oz of fluid, so need to buy that amount.
Old Nov 12, 2019 | 01:34 PM
493lszosix's Avatar
493lszosix
Thread is from 2010, hopefully the op has gotten it figured out by now 💁‍♂️
To c5 rear diff fluid? - Tranny?
Old Nov 12, 2019 | 01:53 PM
Chillo32's Avatar
Chillo32
Stick with OEM. It’s recommended for a reason.
diff 88862155
trans 88832624
Old Nov 12, 2019 | 02:35 PM
INSTIG8R's Avatar
INSTIG8R
diff 88862155
trans 88832624
Ignoring that this is a 9 year old thread, this is a flawed statement to make too
The parts our cars use were being designed 25+ years ago. The notion that nothing better has come along since the last C5 rolled off the line is asinine. Not to mention factory built cars are produced with certain mileage, wear, emissions, and fuel mileage goals. There are plenty of examples where switching to thicker than factory oil may give up a few mpgs, but gain a lot of protection. With modern technology, there's no reason to assume every aspect of the car can't be improved on with negligible side effects.
Old Nov 12, 2019 | 02:42 PM
Chillo32's Avatar
Chillo32
with this logic, you might as well replace every component of the car and update it. We are driving 25 year old cars. The entire car is old technology. Certain components can be replaced and improved upon like an ATI dampner, clutch perhaps. While others, are recommended for a reason. Mobile 1 oil is still pretty good stuff “25 years later.” Stick with what the auto manufacturer recommends and you won’t create more problems for yourself. If you’re of the mindset that cars have improved in the last 25 years, then put your order in for a c8.
