Powder Coating intake manifold. Will it work?
Old Mar 12, 2002 | 06:47 PM
chuckster's Avatar
chuckster
Default Powder Coating intake manifold. Will it work?
I know Powdercoating needs to heat the product to about 450 degrees. Will the Composite intake handle that temp? I want to get a 2002 intake and have it "Chrome" colored Powdercoated.
Old Mar 12, 2002 | 07:22 PM
raymond8pistons's Avatar
raymond8pistons
Default Re: Powder Coating intake manifold. Will it work? (chuckster)
Powdercoating requires that the part to be coated is conductive. I believe the intake manifold is made from plastic, and not conductive. It is possible to have a conductive coating applied to the plastic piece first, and then apply the powdercoat. Your are correct that the part is heated to about 450 degrees during the curing process. It will be expensive to powdercoat the intake.
Old Mar 12, 2002 | 11:15 PM
AP's Avatar
AP
Default Re: Powder Coating intake manifold. Will it work? (raymond8pistons)
Why not try paint? I think that Specter Werkes Paints the intake to match the car ... maybe someone could paint it in a chrome like fashion .... ???
Old Mar 13, 2002 | 12:39 AM
GWPII's Avatar
GWPII
Default Re: Powder Coating intake manifold. Will it work? (NewVetteLover)
Assuming you were able to do this, powder-coating it would make it harder for the intake to dissipate heat efficiently. Why do that? You don't want to do anything that would raise the intake temperature.
I do know that a company "powder-coats" MDF board for table tops and counters, so it can be done with wood products at least.
Old Mar 13, 2002 | 02:23 AM
RCswish's Avatar
RCswish
Default Re: Powder Coating intake manifold. Will it work? (GWPII)
Why don't you have it Jet-Hot Coated bright silver like headers. That would be real cool.
Old Mar 13, 2002 | 09:19 AM
99 Corvette's Avatar
99 Corvette
Why not get the new Holley intake manifold and polish it :confused:
Jerry
Old Mar 13, 2002 | 01:11 PM
chuckster's Avatar
chuckster
Default Re: Powder Coating intake manifold. Will it work? (99 Corvette)
Jerry
Caus it's metal and don't want heat soak. :(
Old Mar 13, 2002 | 01:16 PM
chuckster's Avatar
chuckster
Since the intake is composite it does not need to dissapate heat. Since it really can't absorb any and is a bad head conductor it does not need to dissapate any.
Old Mar 13, 2002 | 02:10 PM
C5Noir's Avatar
C5Noir
Chuckster, there have been many guys on LS1.com paint their intakes very nicely. They can use pretty much any type of paint. Just run it by a body shop and they could do it very easily :) and in any color :cheers:
Old Mar 13, 2002 | 02:33 PM
chuckster's Avatar
chuckster
Default Re: Powder Coating intake manifold. Will it work? (C5Noir)
Thanks for the tip!!!!!
here it is...
check out this chrome plated one!!!! http://www.tunedport.com/ls1manifols...smanifold.html
[Modified by chuckster, 12:36 PM 3/13/2002]
Old Mar 13, 2002 | 03:16 PM
Patches's Avatar
Patches
GAWD!!! :eek: :eek: :eek: That is KICK AZZ gorgeous!
Great job! What color is it exactly?
Very :cool: idea chuckster!
To Powder Coating intake manifold. Will it work?
