2000 C5 Transmission Problem
Old Mar 27, 2010 | 02:08 PM
myrickja's Avatar
myrickja
4th Gear
Default 2000 C5 Transmission Problem
When downshifting into 3rd it grinds badly. I've been told it's a $2000.00 job to replace the sincro. Wouldn't it be cheaper to buy a used transmission? Thanks.
Jim
Old Mar 28, 2010 | 03:58 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Jim
$2000 to replace a syncro?
You can get an RPM Level IV tranny for $1895.
http://www.rpmtransmissions.com/c5pricing.html
Old Mar 28, 2010 | 04:16 PM
k0ts's Avatar
k0ts
Don't forget the price to "remove and replace".. It's a big job.. and a good time to refresh the clutch..
Old Mar 28, 2010 | 04:21 PM
Edmond's Avatar
Edmond
Damn skippy it's a lot of work. Took us about 12 hours yesterday.
RPM is $1900 and a C6 Z06 clutch kit is about $450 or so. It's a good idea to do the clutch as the same time since you have to drop the rear end from the bellhousing and the clutch is only a few bolts away from being replaced. It's there so why not?
To 2000 C5 Transmission Problem
