trouble codes from from the DIC???
Old Mar 12, 2002 | 09:08 PM
Alex03's Avatar
Alex03
Default trouble codes from from the DIC???
I change my MAF housing the other day and it was very simple. I put everything back together and took out for a test drive. But I got some trouble codes. :confused: Does anybody know why I'm getting the trouble codes? Did this happen to anybody else? What can I do? :cry
trouble codes:
10 PCM- P0113 c
10 PCM- P1111 c
Old Mar 12, 2002 | 10:37 PM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: trouble codes from from the DIC??? (Alex03)
Sorry, I cannot tell you the fix but I can tell you the code ?
the C at the end of each trouble code means current
P0113 - intake air temp. - Censor circuit high voltage
P1111 - intake air temp. - Censor circuit intermittent high voltage
I am sure this does not help but here you go................Sorry :confused:
Old Mar 12, 2002 | 11:42 PM
Alex03's Avatar
Alex03
Default Re: trouble codes from from the DIC??? (MilYellow02)
Is this a BIG problem? Do I need to take it in for service? :confused: :confused: :confused: I want to take care of this...... :cry
Old Mar 13, 2002 | 11:44 AM
LovintheC5's Avatar
LovintheC5
I had exactly the same problem not too long ago. If left alone, the car will start shifting funny. (ie:real hard when shifting from park to drive if you have an auto). I delved into the IAT, only to find the wires on the IAT were frayed. I went to the dealer, and got the plug and a new set of wires for about 20 bucks. Turned out the IAT wasnt bad, just the wires. if your wires are OK, you can also just buy a new IAT. I think they are around 30 bucks at the dealer. Good luck
Daren
Old Mar 13, 2002 | 02:51 PM
Alex03's Avatar
Alex03
Default Re: trouble codes from from the DIC??? (LovintheC5)
I'm kind of slow, can you explain what IAT is? Where is it located? Can you explain how to fix it, step by step. :smash:
Thanks a lot Daren. :cheers:
Old Mar 13, 2002 | 04:07 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
The IAT sensor is the intake air temperature sensor on your air bridge, aft of your MAF sensor. Check to make sure it's plugged in. ;) The wires don't seem to hold up to abuse well... Jiggle the wires a little and listen for changes in the idle quality. The fix kind of depends on what's wrong, but replacing the connector and a short segment of the wires is not uncommon.
Old Mar 13, 2002 | 04:48 PM
Alex03's Avatar
Alex03
Default Re: trouble codes from from the DIC??? (ToplessTexan)
Do I need to disconncect the battery before I start? :smash:
To trouble codes from from the DIC???
